586,106 active members*
3,038 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > [Fusion 360] Micro pauses around corners and any radius
Results 1 to 12 of 12
    Nov 2013
    143
    Hey guys, this issue has been driving me crazy for awhile now, and I don't know if it can be solved.
    Whenever my machine reaches a corner or any radius, the machine pauses for a micro-second just before the corner/radius, then continues around the corner/radius and moves on.
    Is there a way to keep the machine from doing this? It's causing tool marks on all of my parts.
    Is there a setting in Fusion 360 that I can check to make sure the machine doesn't do this?
    1943
    Re: [Fusion 360] Micro pauses around corners and any radius
    More likely a machine setting. Are you using G61 or G64
    Nov 2013
    143
    Quote Originally Posted by 109jb View Post
    How would I be able to tell which setting the machine is curently using? I was doing some reading on this, and it appears as if G64 would be the way to go, but I'm not sure how to go about using it once the g-code has been loaded.
    What control software are you using? In Mach3, there's a status bar listing the currently active g-codes.
    Nov 2013
    143
    At the moment, it's set to G64. I did have the setting "Stop CV on angles > 89 degrees" checked, though. I will uncheck that and see how that affects my work from now on.
    The strange thing is, I can remember CV being disabled on angles less than that.
    Turn off CV Distance and CV Feedrate if they are on.
    Nov 2013
    143
    Yes, all other settings in that section are turned off.
    Check on the Settings page as well.
    Nov 2013
    143
    Ah, I see what you meant now. I was looking at the wrong page. I'll make sure those are off as well.
    Jun 2004
    6618
    Those settings are for different things, but almost as bad as using exact stop mode. Talk about getting the jerk around.
    Lee
    Nov 2016
    28
    Ideally, you want the cutter to slow down a bit in high speed machining so you're not putting crazy torque on your machine. Stopping completely is a little much though. You can control the acceleration and deceleration in mach which will override any jerky moves you might program, and fusion also has variables for acceleration and deceleration which can be useful for speeds faster than you're used to..
    Sep 2009
    1856
    Make sure you are use I and J there is a problem with useing R
    http://danielscnc.webs.com/
    being disabled is not a hindrance it gives you attitude
    [SIGPIC][/SIGPIC]
  1. Pauses in SolidCAM
    By Damien Gajda in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 11-17-2016, 03:21 PM
  2. Help programming octagons with different radius corners
    By 300blkout in forum Daewoo/Doosan
    Last Post: 08-05-2013, 03:11 PM
  3. How to Radius corners of a box.
    By Xterrian in forum G-Code Programing
    Last Post: 06-24-2010, 05:09 AM
  4. Radius's appearing in square corners
    By simso in forum Mastercam
    Last Post: 01-03-2009, 05:10 AM
  5. Letter fonts w/specific radius corners
    By ktuggle in forum Uncategorised CAM Discussion
    Last Post: 02-24-2006, 05:33 PM
