586,114 active members*
3,156 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Want To Buy...Need help! > CNC 3 axis for plastic cutting and milling
Results 1 to 17 of 17
    Nov 2016
    34
    1st post here, in advance thank you for your help! I am amazed at the amount of info I have found here!
    I will be cutting and routing 3 to 5mm recycled plastic sheets. I think using 4X4 size table work space would be best. In the past I knew of a person doing that with very nice results. Unfortunately he is no longer available to ask advice from. I do know that he used vacuum plates and water irrigation on the cutting bit (a flood table I would assume). The edge results were very sharp and clean just what I need!
    So I have been doing tons of research and cannot seem to find a clear answer, suggestions would be appreciated.
    What machine do I need? what power on the spindle is desired? Could I build one myself from a kit?
    Could I take a Plasma cutting table ( the kind that has the water table under it) and use it for the flood table? see below kit
    I have found some great kits.
    I found this company that has plasma and cnc kits, something like this,https://www.wrightmetalworks.com/collections/cnc-router-cutting-table/products/cnc-router-cutting-table
    Thanks a bunch!
    Something like this work? or do I just need to money up for a bigger machine?
    Jan 2007
    1795
    Re: CNC 3 axis for plastic cutting and milling
    yes a machine with vactable you need
    if you have job on hand then go for a ready machine
    something like you can see on this link below
    if you plan to using excassive water cooling.. then you need a tray and clamping option too
    SALE CNC Router Milling, CNC Laser, CNC plasma machine, China, Servo Motor Drive, UK, USA, Italy, Spain, Thailand
    Nov 2016
    34
    Looks like a capable machine for the money.
    Thank you for the pointer
    Nov 2016
    34
    Jan 2007
    1795
    that machine has only round shafts as rails.. you wont be satisfied
    the problem is, you don't want round rails.. they are ""wobbly""
    they working nice with sft materials and lower feedrates..
    you need one at least with supported round rails or better square hiwin rails..
    beyond that personally me , I prefer ballscrew better, but rack n pinion also works well..
    look for this 2x3 machine, its already 5200 because it has decent rails
    that 1212 the best bang, because you have the vacumtable option, tough you might don't need for all work
    I cutting 12-30 inches channel letters, and a couple of screws hold down together the reynobond and acrylic, so I can cut with one setup..
    before order any machine, sure check on rails and driving mechanism
    saving money you might order with ncstudio a 3 axis machine
    for me already two machine works with and I think very reliable
    no tto mention the price
    for ncstudio
    pci card, breakout board 15 pin cable and program itself 40 dollar
    plus 100 a pendant wireless
    for mach3 the program itself cost more, a decent hardware card 150 for mach3 and a better a fast card alredy 350 or more..
    plus a pendant for mach3 also 100
    so eventually for mach3 you going to pay 450 versus ncstudio 150
    Apr 2004
    5737
    It's unusual for a router to use water cooling. Most people cutting plastics do it with air cooling instead, using something like this: https://www.vortec.com/standard-cold-air-guns/overview
    It's easiest to hold flat sheets down using a vacuum table, but that's not compatible with water.
    Andrew Werby
    Website
    Nov 2016
    34
    Thank you again for all of your great information.
    How do you know that it has round rails? I look at the description and I can not see that info.
    I agree the 1212 is a great value machine. Lots of features and performance for the money.
    Nov 2016
    34
    Quote Originally Posted by awerby View Post
    I agree it is a complex issue but I do know it can be done. The finish edge on the plastics that I have from that process are very very nice.
    Jul 2009
    219
    Edge finish can be perfect with no coolant too. I machine all kinds of plastics, UHMW, Delrin, Polypro, etc.... One thing that helps immensely is to figure out what the best finish pass is. On some plastics I leave a .01" for a finish others .005". I don't use coolant often though sometimes you do need an air blast just to clear the chips away.
    You didn't say what type of plastic though and that will make a huge difference on how fast how nice you can cut.
    Nov 2016
    34
    Quote Originally Posted by A1CNC View Post
    I will be cutting HDPE and recycled HDPE
    I have been doing lots more reading, looks like I will have to try the dry method!
    THANK YOU
    Jul 2009
    219
    Just as an example on HDPE,
    .25" 2 flute carbide cutter, .125" deep, .25" wide cut 10k rpm 80"/ minute.
    This is from Gwizard with adjustments made from past experience that I know would work on my machines. So this would be a roughing pass and the finish pass speed would be ~40" / minute depending on how the finish comes out on the 1st part.
    Nov 2016
    34
    I would really like to be efficient and do all cuts/routing in one pass.
    This is what I am trying to duplicate.
    This is a smaller size machine than suggested by others here. Does anyone recognize it?
    https://www.facebook.com/skadinordic.../533016169642/
    Jan 2007
    1795
    you asked
    because Chinese working of precast parts
    means someone casting thoushands of, and they sell small companies the castings
    that kind designed with shafts
    others has a ""step"" on the machine side and those using supported round rails, or hiwin rails
    I had first that kind and was very wobbly
    could not take deeper passes
    Jan 2007
    1795
    in hdpe you can take passes as the diameter of the bit with one flute bits..
    so a 1/8 bit takes 1/8 depth..
    I just cutted signs of
    need new bit to keep sharp edges without fusses
    Nov 2016
    34
    Looking at the size of the vacume plates I purchased and the video I posted below, it looks more like a cnc mill not router table was used.
    Something maybe like this?
    What do the experts reveal?
    Jan 2007
    1795
    that has small table and more rigid, due the gantry is fixed and table moving
    it is a good deal also, but I think you have to count on sheet goods, what is 4x8 feet
    the 2x3 feet machine already small and quite aggravating to cutting sheets down to fit between gantry
    he has also 24x24 inch sized, and that made of cast iron..
    for plastic, a router with square rails is plenty good..
    Jul 2009
    219
    In truth for machining plastic either will work. It just depends on how much you want to spend and how much space you have for a machine. Even a Taig could machine plastic.
    If you look closely at that video you can see the bit is cutting through a thin layer at the bottom that is holding the remaining stock aroud the outside of the parts.
  1. 5 Axis CNC Plastic Cutting Router "The CutaRouterer"
    By ChristianLL in forum CNC Wood Router Project Log
    Last Post: 03-02-2018, 10:04 AM
  2. Replies: 0
    Last Post: 11-06-2014, 08:15 AM
  3. Milling a plastic with a CNC 770 milling machine
    By Edmond Young in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 07-12-2013, 02:55 PM
  4. low cost,long axis plastic cutting
    By threeninethree in forum DIY CNC Router Table Machines
    Last Post: 05-11-2010, 09:59 AM
