586,077 active members*
3,938 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Rapid Turn: Setting work and tool offsets (again!)
Results 1 to 8 of 8
    Mar 2016
    54
    I can't get my head around X and Z axis tool offsets in conversational mode when the work offset is changed; this with the Rapid Turn's QCTP.
    In the RT manual (section 4.1.5 onwards) the procedure is as follows:
    1. Start with an empty tool table (click 'Reset Tool') then using an empty tool holder touch-off the workpiece and enter the appropriate values for X and Z in the DRO section of the screen.
    2. Mount the first tool (say tool 1, a RH turning tool_ and touch-off for X and Z, but using the 'Touch X' and 'Touch Z' buttons on the offset screen for tool 1. This sets the tool-length offset for tool 1 (compared to the empty holder)
    3. Mount subsequent tools and enter their X and Z offsets to add each record to the tool table.
    So, this is fine for the workpiece as originally set. My problem is what happens when the work offset is changed, say when the workpiece is removed from the chuck, turned around and you need to machine the other end? There's always a 'live' tool shown (i.e. the last one used) so if I swap the tool-holder for the empty one and touch-off the workpiece to set a new work offset (zero), it affects the offset for the tool currently shown in PathPilot.
    Do I have to number the empty toolholder (say) 99 and enter it before setting a new work offset? If so, how do the other tools in the table relate to this one? The only way I've found around this is to touch-off all tools again for the new work offset.
    Clearly, I'm doing something wrong but I've been thro' the manual, and Youtube vids for the Tormach lathe, and still can't see it! Any pointers as to where I'm going wrong will be very gratefully received......
    Cheers, Andy
    Jun 2007
    5
    Re: Rapid Turn: Setting work and tool offsets (again!)
    Think of the empty tool holder like using the Haimer in milling mode. Mine is tool 1 in milling mode and when you set the z height in mill mode with the Haimer it adds all the other tool offsets based on that number. So when you flip your part, switch back to the empty holder, be sure the machine is set on tool one, and reset your zero. All the other tools you have loaded are relative to that first tool. You really could do anything for tool one, even load a dial indicator in it (or probe) and use it just like in milling mode.
    Mar 2016
    54
    Quote Originally Posted by dobey View Post
    Thanks dobey - very helpful! I'll certainly try that, using the empty tool holder as 'tool #1' and go from there. I may also experiment using a Haimer in a QCTP holder (boring bar holder with enlarged mounting hole to 12mm) and that will be easier and more accurate to set work zero with the Rapid Turn. I guess my confusion was about when to set zero using the DRO in Pathpilot, and when to set it using the tool-offset page (e.g. 'Touch X'). I shall experiment with great care!
    Cheers, Andy
    Jun 2007
    5
    Went through the same exact process you did, got mine the day they came out. I like that idea too, I will see about making a boring bar holder into a Haimer holder as well.
    Feb 2007
    1538
    Quote Originally Posted by Fortune7 View Post
    Cheers, Andy
    Hi Andy. I am just learning this so I am not quite 100% up to speed yet. But I think this may be the key when you turn your part around or change the Z work position..
    If you use the touch off DROs - you change just that tool number - so that means you have to change every one via that method - not good.
    But when you need to change the Z on all tools, make the change eg via a convenient tool - make sure that tool and corresponding number are set via MDI - and just make the Z position change via the main DRO, this I think will automatically reset all the other tool offsets by the same amount.
    cheers keen
    Mar 2016
    54
    Thanks, Keen - very helpful and verifies what dobey said above. These days I need 'simple understanding' of such things; I'm not working constantly with the Rapid Turn as a hobbyist and in-between uses (could be a few weeks or even months!), it's easy to forget the processes involved, particularly if the manual doesn't cover it too well!
    Cheers, Andy
    Mar 2017
    5
    Hello everyone, I am new to the cnczone but am reaching out for some help with the work and tool offsets. I am having to reset tool offsets everytime I add more stock or start a new project. I assumed once the tool offsets were done initially I would not have to reset unless I change out the tool or need to compensate for tip wear. I don't quite understand the common tool concept but am willing to try if someone could help me understand it a little better.
    Bob
    Feb 2007
    1538
    Quote Originally Posted by meierrh View Post
    Bob
    On Tormachs youtube channel watch Daniel Rogge and Mike Torless videos on this subject - together they give a good explanation.
    Cheers Keen
  1. Rapid Turn: Setting Tool offsets and Y axis zero for QCTP
    By Fortune7 in forum Tormach Personal CNC Mill
    Last Post: 11-21-2016, 05:23 PM
  2. Replies: 2
    Last Post: 12-23-2015, 05:52 PM
  3. Setting work offsets on my cnc lathe.
    By drumsticksplint in forum Fanuc
    Last Post: 06-22-2015, 04:51 AM
  4. Setting Tool and Work Offsets
    By Donkey Hotey in forum Haas Lathes
    Last Post: 06-11-2015, 06:40 AM
  5. Setting Work & Tool offsets
    By Shizzlemah in forum Fadal
    Last Post: 04-16-2005, 06:04 PM
