587,065 active members*
3,747 visitors online*
Page 1 of 3 123
Results 1 to 20 of 44
    May 2006
    67
    Building JGRO - questions
    Ok I have a few questions about building a JGRO.
    On the parts list its says cnc_dtl12 www.rockler.com -- --- HOLD DOWN CHANNEL. I quickly looked at their site. What exactly am I looking for?
    The on cnc_dtl01 and 02 there is some holes marked thru all, and some that aren't marked that. Does that mean that the thru all are drilled thru both sheets, and the other one just thru the top? (pages 18 and 19 in the pdf)
    This is my first machine and my set into CNC. My uncle has a mill and lathe and I am hoping he will help me build this machine. Hopefully I will learn more about machining while working on this.
    Oct 2004
    727
    CNC_dtl12 Sources:
    Rockler Aluminum T-Track
    McMaster-Carr T-Slotted Mounting Track
    INCRA T-Track and T-Track Plus at WoodCraft.com
    All of the holes on CNC_dtl01 and CNC_dtl02 are drilled through all (both sheets). What I did was cut the four 8.250" x 32.500" pieces oversize by about 1.000". I then glued the pieces together to make the two supports 1.500" thick as shown in the two drawings. When the glue was dry, I measured and cut the two supports to the proper size as shown in the plans. After cutting the end supports to size I laid out the hole locations. I then clamped both CNC_dtl01 and CNC_dtl02 pieces together making sure that they were square, flat and the hole layouts were correctly aligned. I then drilled all of the holes that were the same size completely through both assemblies at one time to make sure they were properly aligned. I then separated the two pieces and drilled the through holes that were sized differently in both pieces. It may not have been necessary but it made everything line up much better. I used the same technique for the Gantry Sides (CNC_dtl16 & CNC_dtl17). I hope the above makes sense. Make sure you measure and align the pieces more than TWICE (you know the measure twice and cut once rule) because if you don't and something isn't exactly right you ruin 4, fairly sizable, pieces of MDF!!!
    BTW, I used a hole saw set and spade bits to drill the larger holes and it was a total PITA. I more or less burned my way through the MDF while stalling the drill press motor repeatedly. Other people have used Forstner Bits and seemed to have better success. Just a FYI. You may want to give the Forstner Bits a try, I know if I built another one I would.
    That's probably more information than you needed but I hope it helps your JGRO build go smoother. And, last but not least, WELCOME to CNCZone!!!
    HayTay
    Don't be the one that stands in the way of your success!
    May 2006
    67
    lol thanks for the welcome and the help.
    I learned this year how do to CAD work, but I was taught differently then how he has everything layed out. I am slowly figuring it out. I probably won't start for awhile (zero cash and time) but I can get started on the delrin pieces (have that at work). And yes what you said did make sense.
    Oct 2004
    727
    If you haven't already done so, download the JGRO Plans in SolidWorks format (~24.6 MB zipped) and the FREE SolidWorks eDrawings Viewer so that you can get a better look at the assemblies (.SLDASM) and construction. SolidWorks eDrawings Viewer is definitely a 'Cool Tool'. You can zoom, pan, rotate, hide, change views, etc. just like in SolidWorks. One of the 'Coolest' 'Cool Tools' is the ability to right click on an item, or selected items, with the mouse and use the 'Make Transparent' feature to be able to see through those parts.
    Oh, and along with the eDrawing and SolidWorks file formats, SolidWorks eDrawings Viewer also allows the viewing of AutoCAD DXF & DWG formats.
    HayTay
    May 2006
    67
    Thanks again. The plans make way more since now. I can't wait to get this built. I have so many plans I could do with it.
    ok I have another question on dtl11. It says flanged bearings and mcmaster. I am putting together a parts list so I can order the parts. What exactly am I looking for. I looked quickly threw the drawings but I am lost. The parts list doesn't give me any dimensions
    Oct 2004
    727
    Quote Originally Posted by pntbllrsprky View Post
    McMaster-Carr Flanged Bearing - Double Sealed 1/4 x 11/16" - Part No. 6384K352 - $5.19 US each
    Also from McMaster-Carr: White Delrin Sample Sheet— Size is 6" x 6" x 1/2" - Part No. 8573K1 - $10.13 US each.
    I know you're going to ask about this eventually, so I'll give you a 'heads up'. For all of the screws, nuts, bolts, washers and misc. hardware look to Bolt Depot. Good prices, fast shipping, parts in stock and no minimums! Make sure you order at least a couple of extra of each because you'll wind up using them for other things once you get the base table built.
    You'll be looking for bearings, too. Either do a search on eBay or go to VXB Ball Bearings. Make sure that you get bearings that are sealed and/or double shielded to keep the dust and chips out of them. Again, order more than you need, without going overboard, as you will probably find other uses for them (like your next CNC Table) .
    Happy shopping ,
    HayTay
    May 2006
    67
    lol I already found the delrin (I have used mc master before)
    It was just questions on things I didn't know about. I found 30 bearings on ebay for 17 bucks shipped from XVB.
    I am thinking of making the adjusment blocks from delrin also. Is this a good idea?
    edit: Ok thanks for the tons of help. I am in luck when it comes to machining because I have access to a mill and lathe.
    I have found the 1/4 20 threaded rods on ebay. Should I just order 2 6' sections of it (dollar a foot roughly) then just cut it on my own?
    Also I think I probably won't build the adjustment blocks from delrin unless my uncle has some spare material laying around. It would be pretty pricey to do it other wise. Biggest hit on the wallet (besides for motors and controller, which I was planning on hobby cnc kit, unless you have a better idea, I can solder on my own, and I can chemically etch a pcb if need be) is going to be the gas pipe.
    Oct 2004
    727
    Why buy them off of eBay and pay shipping and handling and risk having them bent in multiple places while in transit? You can just pop into your local Home Depot, Lowes, ACE Hardware, Menards, etc. and hand pick the straightest, cleanest threaded rod you can find. You pay a little extra in tax but save on the S & H.
    You can make the adjustment blocks out of almost anything that is at least 3/4" thick and solid enough (delrin, cast acrylic, oak , steel, aluminum, etc.) when drilled and tapped to allow the 1/4" - 20 bolts to be tightened to hold the gas pipe without cracking or splitting.
    Keep on truckin'. It sounds like your well on your way.
    HayTay
    May 2006
    67
    lol good point I never thought about that.
    I just don't feel like working with a ton of MDF. The more I can make out of delrin the better, since I have that at work, and we have experience in milling it.
    Dec 2006
    775
    I just finished making my adjustment blocks out of MDF. I really don't like working with MDF but hey, these are great plans, and I'm giving it a shot. I can change it to Delrin at a later date if I need to.
    Dave
    Feb 2006
    170
    I am starting to collect parts to build the Jgro CNC Router, I was wandering can I use 8mm metric stainless steel threaded rod instead of the 1/4 inch versionsand can I also use 20mm thick acrylic to make the adjustment blocks.What about the limit and home switches could I use proximity switches or microswitches.
    Dec 2006
    775
    Edmond,
    Yes you can use 8mm threaded rod instead of 1/4 inch. How many threads per inch is your 8mm rod? The 1/4 inch rod has 20 threads per inch. I'm pretty sure you will be happiest with a larger number to threads per inch (or cm). On my foamcutter, I use a 3/8-16 all-thread. For my router, I'm going to be using a 10 tpi.
    Dave
    Feb 2006
    170
    Smile
    The 8mm metric threaded rod has about 20 TPI with a thread pitch of 1.25mm, I might think about using 10mm metric threaded rod which has 17 TPI and a thread pitch of 1.5mm.Im just a bit worried about using the 1/4 inch or 6mm threaded rod, it seems a bit thin.Can I make the anti backlash nuts out of Acetyl?.
    Thanks for the help, im new to the whole CNC thing even though I operate a Multicam CNC Router
    Dec 2006
    775
    edmond,
    Many guys have been successful with the 20 tpi pitch, however after a while, the need for speed will seep into your desires. Anything up to 10 tpi is ok for the small steppers.
    I hope others will voice their opinions too.
    Dave
    Nov 2006
    296
    Glidergider,
    what speeds do you get with the 3/8" 16 threaded rod? that's what i have for my jgro, was thinking about 1/2" threaded rod to get more speed, being by it's thicker shouldn't whip as fast (my x axis being about 60" long), hoping to get in the range of 60ipm+, but i'll need to know if the 200 oz/in steppers can handle it, if the 3/8" 16 can do it, i'll be happy, this is my first machine so i can't say i have any knowledge of how they work, you know what they say..... nothing beats experience.
    Dec 2006
    775
    tajord,
    Apples and oranges, they both nurish and taste good, but they are so different. My foamcutter's speed is very slow, and is artificially limited by the software (GMFC) that drives it. Yet I did want to go faster.
    Bottom line, I can't compare the speed of my system with one driven by Mach3.
    Soon, I'll load up Mach3 on that system and see how fast it goes.
    Dave
    Nov 2006
    296
    keep me informed
    Feb 2006
    170
    Thanks Glidergider.
    I will probably use the 10mm metric threaded rod 17 TPI with 200 oz/in stepper motors.
    May 2006
    67
    well I got more questions (go me)
    Is it better to build this out of MDF or plywood? What thickness of plywood would work fine for this. Would it be same as the MDF specs?
    What is a good controller board that is cheap (free is a plus) that I can etch myself. I don't want to pay an arm and a leg for something I can't afford. Plus I like building electronics, gives me something to do. Still haven't figured out what motors and router I am using yet, but I could get the rest made pretty quick.
    I got my job back so I am going to deffinatly modify the plans on this to make it a better machine. I have talked to my uncle about this and the machinist in this is making it MUCH more expensive, but I can get all the pipes turned to be exact and stuff like that. Should be a fun project.
    It has gotten to the point where I have nothing better to do, which means I need something to do, and I think this could be it.
    Feb 2006
    170
    Smile
    I would use plywood as it is easier to tap and cleaner than mdf, it also doesn,t warp as bad as mdf.Regarding the controller board you can check out www.pminmo.com they have a wide variety of controller boards you can make yourself or if you prefer a well designed controller kit with a ready made pcb check out www.hobbycnc.com you just need to solder it together they also have a complete cnc package with motors and all.I am also going to build the Jgro, still collecting parts.I also want to modify the pipe rail design with something a bit stronger.
Page 1 of 3 123
  1. Diary of a FoamCutter building a jgro router table
    By Glidergider in forum Commercial CNC Wood Routers
    Last Post: 11-29-2010, 08:09 PM
  2. JGRO questions
    By randyf1965 in forum Commercial CNC Wood Routers
    Last Post: 01-19-2007, 03:29 AM
  3. Building CNC Surface grinder - whole lotta questions
    By rashid11 in forum Uncategorised MetalWorking Machines
    Last Post: 03-09-2006, 09:53 PM
  4. JGRO router basic questions
    By bubbahotep in forum Commercial CNC Wood Routers
    Last Post: 09-29-2005, 02:14 PM
  5. Questions about JGRO Router
    By ignatz in forum Commercial CNC Wood Routers
    Last Post: 06-02-2005, 04:27 PM
