586,096 active members*
3,012 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > CNC Plasma / Oxy Fuel Cutting Machines > Port 1 Pins current State - input pins flickering on and off in diagnostics screen??
Results 1 to 3 of 3
    Aug 2016
    22
    Switched from PNP prox's to microswitchs, wired NO with shielded 22awg 2 conductor cable. tied the shield on the cabinet end to earth ground. when I view the Mach3 diagnostics screen, the input pins flicker on and off, along with there respective Input switch indicator (yellow squares flickering on and off, constantly triggering reset) is my 400ma power cube to small for the long cable runs @22awg? Do I just need a better 5vdc power supply? why is the breakout board seeing this sporadic on off state? thanks.
    Mar 2007
    2083
    Re: Port 1 Pins current State - input pins flickering on and off in diagnostics scre
    two questions
    1)
    are all of your switches connected in parallel with both of the wires being connected to the breakout boards input ?
    2)
    what breakout board are you using ? - some breakout boards have a high input impeadance
    with normaly open switches the wiring is more likely to pickup electrical noise -
    as a test trigger or short a switch and see what happends on the diagnostics screen
    do you now have a solid green indication ?
    John
    like John-100 with normaly open switches the wiring is more likely to pickup electrical noise
    try to increase mach3 debounce in general configuration
  1. wiring a 5vdc solid state relay to output pins 1.14.16.17 on a c10 board
    By ProtoXNH in forum DIY CNC Router Table Machines
    Last Post: 10-29-2016, 04:37 PM
  2. Noise in input pins
    By Shessek in forum DIY CNC Router Table Machines
    Last Post: 01-12-2016, 11:27 AM
  3. Ports & pins issue (2-9 as input)
    By jderou in forum Mach Software (ArtSoft software)
    Last Post: 12-14-2013, 10:38 PM
  4. Can you use two BOB if you want more Input pins?
    By Mr.Chips in forum CNC Machine Related Electronics
    Last Post: 12-25-2008, 04:18 PM
  5. Parallel port+ input pins for use with EMC
    By visky in forum CNC Machine Related Electronics
    Last Post: 10-26-2008, 10:18 PM
