Originally Posted by
ozzie34231
I remembered that I have the accuracy test sheets for the machine.
The model is an ST-N tested 1976. Machine 56021
Underthetire, the company name is Shizuoka, U before the O. Why would they put 1 3/32" ball screws on a manual machine? Anyway I don't really care about all that, I am just inquiring about the size cuts this machine would be expected to handle, and if under the circumstances I enumerated would a slight shaking be normal, or should I look for additional adjusting.
Muzzer, your machine has more bulk than mine. When I acquired it the dealer said it weighed about 4000 lbs. Do you have any idea what vintage your machine is?
I adjusted the Gibs by first loosening the lock screws, then tightening the adjustment until the table locked, then backed off to a snug setting. Then I locked again. Using dial indicators I cannot see any deflection when I push or pull, and that is true for X,Y, and knee. I attribute that to my just not being strong enough, I'm 78. Under no load, my servos draw just under one amp.
There are two places I'm not sure about. The two knee Gibs appear to only work against movement in and out, i.e. rotation about the X axis. I don't see how rotation about the y axis is adjusted. Perhaps it was expected that the knee always be locked when milling?
The other thing is that the Y axis has box ways and although I adjusted for side to side play, I did not lay under the machine to adjust for up and down play, if there is any.
Ozzie
