586,103 active members*
3,456 visitors online*
IndustryArena Forum > CNC Electronics > Phase Converters > Rotary phase converter question
Results 1 to 7 of 7
    Oct 2005
    99
    Hello everyone,
    I just bought a Mazak QT8 CNC lathe. It came with an American Rotary AD10 converter and I put it in my residential garage. Everything is wired and operational, and when demand is low (reduced rapids and slower spindle speeds) everything works fine. But when performance is required, I get a X axis servo alarm. I suspect the rotary phase converter is undersized and allowing the voltage to drop.
    Here is the question. Can I add a 3 HP 3 phase motor to run with the idler to help prevent the problem? I have the 3 hp motor on the shelf for another project, so it would be easy to try it. I also have a 3 HP knee mill currently wired with a static converter. It would be easy to remove the static and wire it to the rotary, as well.
    I seem to recall the loads will add up to help start larger motors, but my research today has failed to turn it up.
    Thanks!
    15362
    Re: Rotary phase converter question
    Quote Originally Posted by Ron Thompson View Post
    Hello everyone,
    Thanks!
    You alarm is probably an over voltage from the wild leg, a normal problem with RPC's it will kill the servo drive with time
    Adding another motor would only make it worse, running a RPC for any CNC is never a good idea, some CNC machines work ok with a RPC but most will have some kind of problem, Phase Perfect is the only real way to get good reliable 3 Phase power from a Single Phase connection
    Mactec54
    Oct 2005
    99
    The RPC is rated for CNC. I'll check the voltages first chance I get. Thanks!
    Oct 2005
    99
    OK, I did some checking. Attached is the voltage data under various conditions.
    Attachment 341698
    It looks to me like the additional idler affected the balance, as I would expect. (the wild leg voltage actually dropped.) So I assume I could add capacitors to re-balance and bring the voltage up..
    I loaded a program and was able to rapid without an alarm, so progress. With the machine just running the spindle,
    I was able to get the spindle to about 3500 rpm before it alarmed. The max is 4000. So better, but not quite there, yet.
    My conclusion is I could add maybe a 5 hp idler in addition to the existing 10 hp idler and re-balance with additional capacitors.
    Any thoughts, anyone? Thanks.
    Jan 2015
    138
    I don't know Ron, those voltages aren't off by significant amounts. Maybe something other than voltage is going on. Not sure what to suggest.
    If it was a voltage balance issue, I would balance with caps rather than go to a 5-10HP idler.
    Steve
    Oct 2005
    99
    I lucked into a WEG brand 3 phase 10 HP motor from an Ingersoll Rand air compressor for $75. I just got it wired to the 10HP rotary phase converter and it works OK, just a little noisy. I may try to reverse it and see if it is any quieter, or it may need some grease.
    I have a bunch of run caps I bought off of Amazon.com, but haven't tried to balance it, yet. The voltages are a little lower, indicating the need for balancing.
    L1 TO L2 = 245.0
    T1 TO T2 = 244.9 (Same as L1 and L2 but past the contactor)
    T1 TO T3 = 239.7
    T2 TO T3 = 234.0
    I am out of time for today, I'll update this when I have more data.
    Jan 2015
    138
    I bet it gets quieter when you balance with the caps.
    Steve
  1. 3-Phase Quality From Rotary Phase Converter
    By yoopertool in forum CNC Machine Related Electronics
    Last Post: 04-01-2015, 04:44 AM
  2. rotary phase converter
    By fastleather in forum Want To Buy...Need help!
    Last Post: 12-15-2010, 02:40 PM
  3. 760-22 with rotary phase converter?
    By tstom in forum Bridgeport / Hardinge Mills
    Last Post: 03-03-2008, 07:34 PM
  4. AC unit -> rotary phase converter?
    By loves80z in forum Phase Converters
    Last Post: 11-02-2005, 11:23 PM
