Thank you for the information, but now my problem is; when I set the parameters for X and Y on the RD Work 8 program it process fine, but on the actual machine it dose not process the information.
Example if I program the X axis to 700mm and the Y axis to 560mm. on the program it records fine but on the machine X is @ 10000mm and Y is @ 10000mm so the laser head is going to bounce on the sides.
Can you help me with this problem.
