586,734 active members*
2,831 visitors online*
Results 1 to 6 of 6
    Dec 2016
    29
    Parameters inputting procedure
    Hello everyone.
    I have just changed the motherboard of my Fanuc OT series lathe which was malfunctioning. I have the parameters list. Need assistance on the procedure to follow when inputting the parameters. What l have been doing so far has met with limited success. Assistance would be greatly appreciated.
    Sent from my SM-T217S using Tapatalk
    Feb 2009
    23
    Re: Parameters inputting procedure
    Hello
    Wen you hawe the problem with motherboard did you screen was blank and the machine will not start?
    Did you bay new motherboard or did you hawe to send to the repair company?
    Can you tell as the type off fanuc motherboad was?
    We hawe the same problem on fanuc op-b punching machine murata wiedemann centrum
    The scren will not start its blank no start in the machine
    Hope you fix your machine
    Best regardes and thanks in advance
    Dec 2016
    29
    Hello
    I can assist you in fault finding on your screen. Turn power on and check if if you are getting 24VDC on the power cable supplying power to the screen. If you are getting the 24VDC then your screen needs replacement.
    As for my motherboard, l ordered one and they sent me one that was refurbished and tested in Japan. My screen showed this screen which means that your mother board is faulty
    Dec 2016
    29
    Dec 2016
    29
    The procedure that l used is as follows:
    Press reset + delete at the same time snd turn on power to clear memory.
    Press E stop btton in.
    Get into MDI mode.
    Input the dpecisl setting parameter, the 900 codes, first.
    On completion l turned off the machine isolator and then on again.
    I then fed the rest if the parameters.
    Not sure how yo proceed from there on coz the guys who were providing me eith dupport then decided that they won't assist any more fue to dome confidentiality clauses they have in thrir contracts etc.
    Thats where l am stuck now.
    Dec 2016
    29
    Quote Originally Posted by frigoteknika View Post
    Hello
    The motherboard is a fanuc OT.
    Quote Originally Posted by lectriceng View Post
    Hello
