586,260 active members*
2,943 visitors online*
    Oct 2016
    7
    Need help on parameters x and y
    I have a 60wtt laser cutter, once I changed accidentally the parameters while installing the rotary device. now I have the X axis for 10000mm and the Y axis for 10000mm, when I changed the parameters to the actual working size 500x700mm I RESET XY AXIS and it does change back to th 500x700 but once I turn off the machine it goes back again to the 10000s
    how can I save these parameters to the main board,
    the head is messed up in the xy parameters. Can someone please help me how to reset all this to default both the origin and table size
    PLEASE,
    Thank you in advance
    Jan 2008
    940
    Re: Need help on parameters x and y
    when you set it in your vendor settings you have to write it to the machine
  1. Replies: 3
    Last Post: 10-22-2020, 09:20 PM
  2. Nc parameters need help please
    By jasko_deckel in forum Questions or Problems
    Last Post: 02-29-2016, 07:18 AM
  3. PARAMETERS
    By bigbaz in forum Haas Mills
    Last Post: 09-22-2009, 05:32 AM
  4. G83/G87 parameters
    By DocHod in forum Fanuc
    Last Post: 11-04-2007, 08:54 PM
