586,111 active members*
3,184 visitors online*
Results 1 to 6 of 6
    May 2006
    265
    Insert for 62 Hrc
    Is there any insert that will manage to bore up a 24mm hole to 26mm and relocate it 1mm, in a hardened steel that are close to 62 Hrc ?? Geometry of insert should be dcmt 11T3xx Thanks
    Oct 2006
    586
    i dont fully understand the relocate part, and what kind of tool are you using
    individual who perceives a solution and is willing to take command. Very often, that individual is crazy.
    May 2006
    34
    Check with your supplier for a CBN insert in the DCMT style. CBN is expensive, but well worth it. If it is 1 piece, you might get away with carbide, running dry and slow. LIGHT cuts!!!
    HTH
    Aug 2006
    246
    Sounds like you're trying to repair a part. Can you EDM? If it's a repair it may be less of a headache.... You could also look into ceramic in addition to CBN. They may be a little cheaper. There was a post recently about silicon nitride inserts in this forum. I believe they were from Ingersoll cutting tools. You may want to look into them as an alternative.
    :cheers:
    I don't know much about anything but I know a little about everything....
    May 2006
    265
    Quote Originally Posted by cdlenterprises View Post
    :cheers:
    What do you mean with EDM?
    Jul 2005
    442
    Electro Discharge Machining
    You could easily offset the hole with an EDM where the interupted cut would be a little hard on an insert
    aaron
  1. Indexable insert tooling for newbies
    By Dan S in forum Mini Lathe
    Last Post: 12-30-2006, 12:02 PM
  2. Insert Milling Tools?
    By Joseph Souza in forum MetalWork Discussion
    Last Post: 10-19-2006, 02:26 AM
  3. Anyone make their own lathe insert toolholders?
    By Zumba in forum MetalWork Discussion
    Last Post: 05-16-2006, 07:42 AM
  4. INsert Molding
    By PC7 in forum Moldmaking
    Last Post: 04-15-2006, 12:56 PM
  5. Identify this insert
    By Cold Fusion in forum MetalWork Discussion
    Last Post: 08-28-2005, 03:56 AM
