586,103 active members*
3,516 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > How do I make these things? (General machining questions)
    CNC Brute Guest
    Ok, normally I can visualize things pretty well, but here's where I am having trouble.
    1. How you machine a square hole in a block of aluminum?
    2. How does knurling work?
    3. I've seen 1/2" plate aluminum with 8-12" holes cut in them how do they cut a hole this big?
    4. I haven't gotten there yet, but how you get something to .001" of tolerance? It seems to me you can't do it.
    5. How do you cut a "ring" (think lathe) around a cylindrical object that is only .062" wide? Isn't that the thickness (roughly) of a bandsaw blade?
    6. How do you taper? Especially on a lathe. Crank both handles at the same time?
    Thanks guys
    Sep 2003
    363
    As in all things, there are many ways to skin a cat. My first advice is to find a hands on course for basic machining, mill and lathe.
    Drill a hole and broach it, drill hole and saw it, drill a hole and file it, there is even drills that will cut square holes.
    You use a knurling tool that has rollers which is forced into the material to cold work the surface into a pattern.
    Mount it to a face plate on a lathe and bore it, use a rotary table on a mill, drill a hole and saw it, use a cnc mill.
    Its easy with good tools, .0001 is tough.
    You grind your cutter to the size groove you want.
    Use the compound rest set at angle, use a taper attachment, use a tracer attachment, use a cnc lathe, hang a stock between centers and offset the tail stock.
    This is just a few answers to these questions, there are many more. After 30 years I still find new ways of doing things.
    Gary
    Jun 2003
    1365
    A good place to start out is this website, I read this thing a few times before I placed my orders.
    http://www.mini-lathe.com/
    heres for the homier lathe:
    http://www.mini-lathe.com/Mini_lathe...er2/Homier.htm
    they also have different mini mills reviewed.
    Jon
  1. Have things wired....now a few questions
    By DAB_Design in forum Gecko Drives
    Last Post: 10-08-2004, 04:17 PM
  2. Bringing objects together in V19 & general questions
    By rustyolddo in forum BobCad-Cam
    Last Post: 07-31-2004, 03:14 PM
  3. A few honest questions
    By HuFlungDung in forum CamSoft Products
    Last Post: 06-16-2004, 12:24 AM
  4. Lathe machining questions
    By devinchi in forum Uncategorised MetalWorking Machines
    Last Post: 02-25-2004, 05:17 PM
  5. ballscrew repair and some general questions
    By jimbo in forum DIY CNC Router Table Machines
    Last Post: 09-27-2003, 09:48 PM
