586,106 active members*
2,935 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > CorelDRAW 12 question "Convert to Curves"
    Jan 2007
    88
    On CorelDRAW 12, under the "Arrange" pull down, there is a selection titled "Convert to Curves". I cannot find out what the default is for it. Say I have a rectangle and want to radius the corners to 0.625" radius, how can I tell when I am there. It has values placed from 0 to 100, but I have no idea what the value is. Can I change the values?
    Did I make sense????! Or am I trying to do it incorrectly. My money is on "I'm doing it wrong"!
    322
    Look at 'round corners'
    Hi, 'convert to curves' is used to make a CorelDRAW shape into a curve object, not for rounding the corners on rectangles. There is an option on the toolbar for specifying corner roundness.
    Quote Originally Posted by blackhollowmfg View Post
    James Leonard - www.DragonCNC.com - www.LeonardCNCSoftware.com - www.CorelDRAWCadCam.com - www.LeonardMusicalInstruments.com
    May 2005
    362
    Use the node tool (F10) and select the rectangle. The corners will turn into black spots. Grab a spot then click and drag down to change the roundness of the corners.
  1. "low end" HF Spindle or "high end" router for about $1000?
    By biomed_eng in forum DIY CNC Router Table Machines
    Last Post: 01-06-2012, 07:15 AM
  2. BattleAxe "aka" Ball and Chain "aka" the wife.
    By ZipSnipe in forum Community Club House
    Last Post: 05-18-2008, 03:53 PM
  3. Vertical system "jerks" and "bangs"??
    By REVCAM_Bob in forum Servo Motors / Drives
    Last Post: 06-12-2006, 03:09 PM
  4. Replies: 2
    Last Post: 01-25-2005, 05:26 PM
  5. Great Freeware - "Convert"
    By Swede in forum Uncategorised CAM Discussion
    Last Post: 01-04-2004, 11:35 PM
