586,385 active members*
3,345 visitors online*
IndustryArena Forum > MetalWorking Machines > Novakon > Novakon Laser Cutter!
Page 3 of 3 123
Results 41 to 42 of 42
  1. #41
    Mar 2009
    388
    Re: Novakon Laser Cutter!
    Quote Originally Posted by ram48 View Post
    Scott
    It is very easy to change from the supplied 63MM (2.5 in lens to the 101MM lens If you look at the tube, it is threaded on both ends the 101 mm lens installs in the opposit end of the tube.
    it is a long thread you just remove the 63mm and insert the 101mm in the other end of the tube,
    make sure the flat side of the lens if facing the work, drop in the o ring and screw the retaining ring down to snug the lens.
    If you have any more questions or would like a pic or two for clarification let me know
    Ray
    Thanks Ray,
    With the 2.5 (63mm) lens we use a 8mm spacer between the end of the tube and the material. Do you use a 46mm spacer with the 101 lens? (101mm - 63mm = 38mm + 8mm = 46)
    Scott...
    Instructional Videos for CNC Guitar Building
    http://www.rmgvideos.com
  2. #42
    Feb 2010
    131
    Scott I sent you a PM
Page 3 of 3 123
  1. CNC Laser cutter versus CNC Plasma cutter?
    By squale in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-24-2020, 02:14 AM
  2. My chinese laser cutter won't work at all, software doesn't see the cutter
    By Sasa1234 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-01-2019, 04:09 AM
  3. 40W co2 laser engraving cutting machine engraver cutter cnc CO2 Laser Engraver Cutter
    By ecpur in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-27-2015, 08:23 AM
  4. Laser Cutting Engraving Machine Laser Cutter 1400*900mm
    By cnc_laser in forum Commercial Laser
    Last Post: 07-10-2013, 08:52 AM
  5. CNC Plasma Cutter, Laser Cutter, Water Jet
    By antsals in forum Waterjet General Topics
    Last Post: 03-11-2011, 01:56 PM
