Hello,
I am working to restore functionality of a mill that had some water damage on the electronics. This includes the PC controlling the mill with Mach 3 and a parallel port. Luckily, I was able to get Mach 3 running on a second PC and controlling the X and Z axes of the mill.
The Y-axis, just like the X-axis, is powered by a G320 controller. I also have two new G320X controllers. The X-axis is fine; it works with the G320 controller that got a bit wet and has dried. The Y-axis moves and blows a fuse rapidly on its old G320 controller with the same wiring, the G320 X-axis controller, and a new G320X controller.
Before the water damage, the mill worked well with the G320 controllers on X and Y.
The fuse is 5 amp, and the controllers are running at about 67 volts.
The Y-axis motor starts moving immediately when we power the geckodrive controlling its motor. This happens on both the G320 and the G320X. The fuse blows shortly after it starts moving. No fault light is present on the controllers. I am using the same wiring, including the resistor between the encoder and error pins, probably the same wiring that worked before it was transported and water damaged. The same wiring is used on G320 and G320X.
I am suspicious about the wiring for this Y axis. The motors are visually identical on X and Y, but when examining the electronics after they were exposed to water, we noticed that the ground wire for the encoder was not connected for the Y-axis. Is there any way this was correct? Or did it fall out during transport? (the mill had been transported and not used for a few months.)
One other peculiar thing is that the G320 that originally controlled the Y axis had a little loop between the "Common" screw terminal and a connection on its PCB just below. Was this just due to a broken screw terminal solder joint? or is it a trick I don't understand?
Here are some photos. The controller labeled "C-6" on top (with its own closeup photo) is the X-axis. The photo below shows both the X- and Y- axis controllers in their water damaged state. You can see the suspicious wire on the bottom left G320, there is a combo green-black-ground twist that is not connected anywhere. The tip of that twisted combo is visible just above a perpendicular black wire. The little red loop I called "peculiar" is visible here too.
https://goo.gl/photos/QzVswPKwJHsR2vWCA
Thanks for your help.
James
