Hey folks, I am having an issue with my Gorilla CNC. Whenever I try to run something, I get a message saying something to effect that the signal generator is not working properly. However, I have sent it back to the manufacturer and they replaced the board and say that it should be working fine, despite that it is not reacting in the way it should be (sequence of lights when turning it on). Anyway, what I'm hoping to do is find someone with a Gorilla machine and the same signal generator that is not experiencing any issues (Flashcut, I can give more details when needed). Hopefully, we can then try hooking it up to your machine to see if it works or if you get the same error. I just want to know definitively whether it is the signal generator or something else that is causing the issue. I will ship it if we are not geographically close. Thanks to any help you can offer. I can post the specific messages that I'm getting if that helps.
Dan
