586,471 active members*
3,876 visitors online*
IndustryArena Forum > CAD Software > Rhino 3D > I need help making a digital scanned .igs part turned in to a solid .igs
Page 1 of 2 12
Results 1 to 20 of 35
    Sep 2013
    131
    Hi everyone, any tips or help would be great. Thank you very much. Picture and model are here. I also have the .stl if that is better to work with.
    Feb 2007
    11
    Re: I need help making a digital scanned .igs part turned in to a solid .igs
    Hi PoolRod2...
    There were some edges not joining up when converted to a solid.
    You can download the solid file here:
    http://www.ted-kyte.com/download/Guitar Neck SOLID.zip
    Hope this helps you out...
    Ted
    Ted
    http://www.RhinoCanada.com or http://www.ted-kyte.com
    Sep 2013
    131
    Hi Ted, thank you for trying. It needs to be a complete solid, so I can pull toolpath geometry from it. This is the wireframe. Would an stl file work better for you?. I put .stl and.stp files in the latest zip. Thank you for your time.
    Feb 2007
    11
    That file I sent should be a solid, it loaded into Solidworks as a solid...
    Ted
    Ted
    Sep 2013
    131
    Hi Ted, when you open it in Solidworks, and run the mouse around it, it has trailing rectangles, not a solid. Thank you very much for trying though.
    Feb 2007
    11
    Hmmmm...
    Well it is definitely ok in Rhino, maybe looses something in the translation.
    Try this .SAT file it appeared to import fine.
    http://www.ted-kyte.com/download/GUI... Solid SAT.zip
    Ted
    Ted
    Sep 2013
    131
    Still no luck, thank you for the efforts, Ted. When highlighted, it looks like this.
    Mar 2008
    683
    Quote Originally Posted by poolrod2 View Post
    The file opened as a solid on my Solidworks. There's surfaces there for your toolpaths.
    If you're looking for someone to remodel this in to a "clean" lofted model you're in the realm of paying a designer for several hours of work. I do luthiery for a living.
    Sep 2013
    131
    Hi Warren, the solid has broken surfaces as shown in the pics, they could be selected for toolpath, but they over run the areas that don't need surface cut. No true wireframes can be extracted either. Thank you for the help.
    Sep 2013
    131
    Here is the Scanned model again. Thank you, everyone for working on this and sharing ideas.
    Feb 2007
    4553
    Poolrod2,
    Is the issue resolved or do you still need suggestions?
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Hello.
    I came across a custom reverse engineering solution in Rhino.
    It seems to be called Mesh2Surface
    Sep 2013
    131
    Great website, Ted.
    Feb 2007
    11
    Thanks poolrod2
    Ted
    Mar 2006
    81
    Hmm... when I first saw this thread, I thought you just needed someone to use JoinEdge on the four surface edges that weren't joined when importing the IGES file into Rhino.
    After seeing a few responses, it looks like we're having an issue with a multi-surface format like IGES, and a NURBs format like Rhino.
    When Rhino imports the IGES file, it's going to be a bunch of surfaces. And it sounds like you want one one smooth surface instead of many small surfaces that when joined together, form a large polysurface.
    Unfortunately, you cannot do this with just a few clicks. You're going to have to use those surface edges as guides to create a new surface in Rhino that's continuous and smooth. Even if you manage to succeed at this, it will not be 'exactly' like the imported IGES.
    As warrenb mentioned, this falls into the realm of 'Hire someone to create it for you' or 'learn how to use existing geometry as the basis for a new model'.
    If I were getting paid to recreate this, I would use some of those spiderweb-looking surface edges to create some lines along with the Duplicate Edge command, Section Command, and ExtractIsocurve Command... and then either Loft, CurveNetwork, or Patch single surfaces until I get something that resembles the original work, and then join those surfaces into a polysurface.
    It's not simple work.
    Sep 2013
    131
    I wish I could pay someone, this is killing me,lol. I tried Catia, Solidworks, Meshcam, Spaceclaim, Freecad, Hypermesh, Designspark, Mastercam, Geomagic Design X, Solid Edge and Rhino, all I need is a solid from an stl to get true solid wireframe from. Thank you all, you guys rock for trying. Happy New Year.
    Mar 2008
    683
    Solidworks 2016 handles it just fine. It IS a solid. See attached
    Sep 2013
    131
    Hi Warren, my Boeing shop I currently work at doesn't have Solidworks, and my home student is 2013. I like the end of that were the mesh was removed, some kind of pinch tool?. I need to machine it without surface cutting the whole thing, just surface the small radius to the head, and the back of the neck and foot transitions. Pics below.
    Attached Thumbnails Attached Thumbnails completed top.jpg   Completed Bottom.jpg
    Feb 2007
    11
    Did here too warren...
    Ted
    Sep 2013
    131
    Happy New Year everyone, thank you for your help on this. I can easily profile the outside with a silhouette boundary and use tabs to hold it in the frame, and then hemstitch both sides, but I would like to just hemstich the radius part of the neck and volute's and the radius from the neck to the head face. I tried to make surfaces and extrude .001 thou, and those small rectangles are driving me crazy,lol. Below is a pic of a model I made, but my radius to th hell and head are wrong. Cheers.
    Attached Thumbnails Attached Thumbnails Completed Bottom.jpg   completed top.jpg
Page 1 of 2 12
  1. Replies: 54
    Last Post: 03-16-2013, 07:11 PM
  2. Need a part scanned - tips/contacts/costs?
    By SRT Mike in forum 3D Printing / Scanning Software and Hardware
    Last Post: 04-21-2011, 09:06 AM
  3. Replies: 8
    Last Post: 12-10-2010, 05:28 AM
  4. Help - Scanned outline to part
    By revwarguy in forum Uncategorised CAM Discussion
    Last Post: 05-05-2009, 01:33 AM
  5. I need a large part scanned in Reno, NV
    By Streamlined in forum Employment Opportunity
    Last Post: 03-27-2008, 06:12 AM
