586,060 active members*
3,892 visitors online*
    Feb 2007
    67
    Extracting current line number using Macro B.
    Hello!
    Once again I'm coming to the CNC zone to help me solve an issue. I'm using a Fanuc 35i control.
    I have a creep-feed grinder that is encountering a spindle overload. I didn't write the program but I'm stuck fixing it. When the overload happens, a macro executes. This macro retracts the spindle to a safe location then does a soft-reset. When this happens, the program rewinds to the beginning, losing the place in the program where the fault occurs.
    My question is this: Does the control store the currently executing line number (N-number) in a parameter than can be extracted? My program has N-numbers on every line.
    If it does, I can modify the macro that retracts the spindle and rewinds the program to grab the current line number and put it in a variable before rewinding, letting me know exactly where the fault occurs.
    Thanks for reading...
    Glen
    Aug 2009
    684
    Re: Extracting current line number using Macro B.
    Quote Originally Posted by grweldon View Post
    Hello!
    Glen
    #4114 rings a bell. I use this variable to return to main program at a specific line number. #4314 may be more suitable though. I think 4114 is last N in buffer and 4314 is last N executed.
    DP
    Feb 2007
    67
    DP,
    Thank you so much for your reply. #4114 does the trick. Exactly what I was looking for....
    Glen
  1. POST 2 SEQUENCE NUMBER ON THE SAME LINE
    By MAINVIST in forum Post Processors for MC
    Last Post: 11-06-2013, 10:31 AM
  2. no line number in comment line in mpos
    By MSFAB in forum Surfcam
    Last Post: 02-13-2012, 11:51 PM
  3. omit line number
    By asjad in forum Mastercam
    Last Post: 05-10-2007, 12:18 PM
  4. G-code ploter with line number annotated?
    By webcruiser8 in forum G-Code Programing
    Last Post: 09-21-2006, 11:49 AM
  5. Line Number Range Error
    By gar in forum Haas Mills
    Last Post: 05-23-2006, 11:06 PM
