586,441 active members*
4,059 visitors online*
    Sep 2010
    56
    Making a negative of a part
    Hello,
    Been struggling with this for a while doing searches and such. For the life of me i cannot figure out how to do a negative of a part. Similar to a mold, i would like to cut out the features of the part in a jig plate for better nesting of the part.
    Any help is appreciated.
    Apr 2004
    5741
    Re: Making a negative of a part
    It sounds like you need to do a Boolean subtraction. Here's some instructions on how to do it: Alibre Options: Using Boolean Operations in a Part Workspace | Cadalyst
    Andrew Werby
    Website
    Sep 2010
    56
    Yep, thats what i thought too. However, when i try to "remove" the part half, it removes improperly and leaves surfaces. Im thinking now I may have a model issue. Its an imported .iges part file which im thinking was not made solid upon import. Is there a way to validate that my part file is a true solid?
    I think that may be my issue.
    Apr 2004
    5741
    You might try running some of the "printability" checks - if it has extraneous surfaces incorporated into the model, that should highlight them: 3D Printability Tools
    Andrew Werby
    Website
  1. Need Help Making Part
    By Jack The Ripper in forum CamBam
    Last Post: 05-01-2013, 05:57 AM
  2. making negative for mold
    By joegalicic in forum Rhino 3D
    Last Post: 04-14-2012, 06:56 PM
  3. Negative of Part - Mold
    By adorsett in forum SprutCAM
    Last Post: 03-15-2012, 09:17 PM
  4. making good negative picture
    By electric2u in forum ArtCam Pro
    Last Post: 05-02-2010, 12:16 AM
  5. Making a positive mold from a negative mold - how?
    By SRT Mike in forum Moldmaking
    Last Post: 03-29-2007, 10:30 PM
