586,116 active members*
3,339 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Amada LAser 2415 with Fanuc Series 160i-L 438 error on Start up
    Mar 2014
    8
    Hello everyone..
    We occasionally get the 438 Y axis INV Abnormal current error some mornings on start up.. We can usually clear it up with a repeating of the start up procedure.. Is there something we can look at to see what is causing this issue?
    Thank you in advance
    Ken
    Feb 2015
    161
    Re: Amada LAser 2415 with Fanuc Series 160i-L 438 error on Start up
    If it goes away after a few start ups, and never happens again throughout the day, it is most likely the drive.
    Try disconnecting the motor power from the drive before start up, if the alarm happens, replace the drive. If not, then the motor resistance phase to GND could be bad.
  1. Replies: 4
    Last Post: 02-21-2019, 08:24 PM
  2. Replies: 2
    Last Post: 07-22-2014, 07:04 PM
  3. Replies: 0
    Last Post: 07-11-2014, 10:14 AM
  4. amada pulsar 2415 cut conditions
    By Apexengineering in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-28-2010, 02:27 AM
  5. Fanuc 160i-M Series Controller
    By kevin08 in forum Fanuc
    Last Post: 07-11-2008, 03:05 PM
