586,075 active members*
4,173 visitors online*
Results 1 to 9 of 9
    Dec 2016
    9
    Radius bend - salvagnini
    Hi everyone!
    Are there people who works with Salvagnini panel bender?
    I need to do a radius bend with shelves on both sides. See attached picture.
    I made a program but it does not give an exelent part.
    The next picture shows how it must be (left part) and we have (right part)
    If you worked with similiar form please help.
    Best regards.
    Sep 2016
    7
    Re: Radius bend - salvagnini
    HI FRIEND
    What software do you use?
    Or do you do it manually
    Is the sysconshelf?
    Is P4?
    If you have these characteristics maybe I could help you
    Dec 2016
    9
    Quote Originally Posted by FREDYABARCA View Post
    HI FRIEND
    Is the sysconshelf?
    Is P4?
    Thank you for replay!
    I had made the first program in Edit P4 software and edited it manually.
    I have a P4 file.
    Sysconshelf... I gues yes. I may check it tomorrow.
    Now I have not an access to that PC.
    Code what I used for bending.
    ROT: S 1
    BEN: L 15.00 A 90.00
    BEN: L 21.64 A 90.00 R 16 STEP 22 AC 12/22 MODE 1
    I think must be some trick for this operation.
    Sep 2016
    7
    Is correct friend
    Mode does not need it
    The program is correct
    Just take into account that when you adjust the angle in the radius, it will correct according to the steps you have.
    In this case you have 22 steps
    How much is here?
    regards
    Dec 2016
    9
    How much is here?
    What about this question?
    Do you mean If I will set the angle 90 I will get different angle after different numbers of steps?
    I always divide Angle Correction on steps.
    I thought we need use ZF statement to approach blade to bending line as we have short shelf before radius.
    I used MODE 1 ZF 1.35
    But it had not helped.
    Maybe we need insert one bend beetwin L 15.00 and L 21.64?
    Some thing like this:
    ROT: S 1
    BEN: L 4.6 A 5.00
    BEN: L 17.00 A 90.00 R 16 STEP 22 AC 12/22
    Sep 2016
    7
    so is . If you are correct you have to decide for the steps you have.
    Other tips.
    You do not need to declare in the program angle of 90 (A 90.0)
    The machine calculates it.
    Unless you use a different angle if you have to declare it.
    example
    A 85.0
    A 45.0
    A 60.0 ETC .....
    And the ZF is to make a more closed angle in the doubles
    Dec 2016
    9
    OK! Thank you! I had forgoten this.
    Another my thought is about different rigidity of our steel comparatively for steel of example part.
    We need try other types of steel.
    Dec 2016
    9
    I had solved this trouble.
    The trick is on the shelf length of bend with a radius.
    It was no any logic as for me but it works.
    For example thickness of panel is 21.5 mm. But L parameter must be less than geometrical size.
    BEN: L 19 R 15 AC 10/18 STEP 18 (but by the drawing L must be 21.5)
    Sep 2016
    7
    excellent friend
    Add me on whatsapp
    Any questions from there we can help
    8991011572
    regards
  1. 2 Cable Chains 1M Long 38mm Bend Radius
    By Atomic_Sheep in forum For Sale Only
    Last Post: 11-04-2016, 11:10 AM
  2. Torch cable fatigue and bend radius
    By jeepsterjc in forum Hypertherm Plasma
    Last Post: 07-02-2012, 01:56 PM
  3. aluminium radius bend marine windows
    By carlos bairo in forum Bending, Forging, Extrusion...
    Last Post: 03-19-2009, 07:32 PM
