586,114 active members*
3,337 visitors online*
IndustryArena Forum > MetalWorking Machines > Auto Tool Changer > Looking for ATC sk20 spindle with accessories
Results 1 to 6 of 6
    Feb 2011
    54
    Hello fellas,
    I am looking a ATC spindle, located in EU.
    The price with 4-5 tool holders, and tool holder cabinet, converter and spindle should not go over 4300 Euros.
    Machining will be mostly steel and aluminium, so lower rpm would be better.
    I am looking for ISEL 2.2 KW spindle, and ISA1500wl.
    I need some good ideas, as my deadline is tomorrow evening, and I have to make a decision. So if any quick triggers here, please shoot.
    Cheers
    Oct 2010
    1189
    Re: Looking for ATC sk20 spindle with accessories
    Quote Originally Posted by lopata View Post
    Hello fellas,
    Cheers
    You mean for a router ? What do you want to mill plastic wood ? Pcb s
    Gesendet von iPad mit Tapatalk
    Feb 2011
    54
    Hey
    I need it for machining metal, mostly aluminium and injection steel molds.
    The lower rpm the better. I am using hsm toolpaths so there are no problems machining those kind of materials.
    Cheers
    Marko
    Oct 2010
    1189
    If you like have a look at our machines we worked on an sk30 spindle which we start to sell from January ,..
    Feb 2011
    54
    Hi
    Can you give me a link to check it out?
    Oct 2010
    1189
    yes Thojomech smart cnc leistbare cnc maschinen sorry the link is in my profile and i don't want to be obnoxious
  1. Enclosure & Accessories for NM-145
    By cteufert in forum Novakon
    Last Post: 09-02-2012, 03:47 AM
  2. Will these accessories fit?
    By earthman in forum Mini Lathe
    Last Post: 01-19-2012, 03:59 PM
  3. $10'000 To set up CNC and Accessories. What would you get?
    By ELM3060 in forum Uncategorised MetalWorking Machines
    Last Post: 09-01-2011, 12:26 AM
  4. 7 x accessories
    By knudsen in forum Mini Lathe
    Last Post: 03-29-2010, 11:09 PM
  5. BP accessories
    By chevdrgtrk in forum Bridgeport / Hardinge Mills
    Last Post: 09-25-2009, 11:32 PM
