586,110 active members*
3,293 visitors online*
Results 1 to 2 of 2
    Dec 2016
    14
    best type of motor spindle is best
    hello all, thinking of buying a cnc router machine can someone please advise on the reasons good and bad for standard spindle motors and flexshaft spindle motors please as not sure which would benifit me best.
    thanking you all in anticipation of wonderful answers.
    Apr 2004
    5737
    Re: best type of motor spindle is best
    A real 3-phase spindle and VFD is much better than a hand-type router, and immeasurably better than a flex-shaft for use on a CNC machine. Spindles are made to run continuously for long periods of time. Hand routers are made to run for the time it takes to make a single cut on a board. Tun them for hours at a stretch and the bearings go out. Flex-shafts have the advantage of transmitting rotary motion from a bulky motor to a slim hand-piece; they are great for intermittent use on small projects like jewelry buffing. But they will quickly die if used for heavy cuts lasting longer than a few minutes at a time.
    Andrew Werby
    Website
  1. CNC Spindle motor power wire type and sheilding from other wires?
    By PIVOTALCUSTOMS in forum Uncategorised MetalWorking Machines
    Last Post: 04-25-2014, 02:50 PM
  2. Need help determining what type of spindle+motor I need.
    By sburck in forum Uncategorised MetalWorking Machines
    Last Post: 01-18-2012, 11:35 PM
  3. Mill motor challenge fun times - what type of motor is this ?
    By nick mulder in forum Servo Motors / Drives
    Last Post: 12-21-2011, 04:52 PM
  4. Replacing Spindle Motor on Prototrak type mill
    By mgb1974 in forum Uncategorised MetalWorking Machines
    Last Post: 07-02-2008, 12:29 PM
