586,538 active members*
2,847 visitors online*
IndustryArena Forum > Maintenance in General > Maintenance DIY Discussion > Best air and suction hoses for routers
Results 1 to 6 of 6
    All,
    My ageing Anderson routers are in need of both suction hoses for the router beds and about a mile of pneumatic hoses, many which ride in the catrac and flex all day long. I'd appreciate suggestions for good hoses for both. I'm in Michigan, good suppliers also welcome.
    Mar 2008
    683
    Re: Best air and suction hoses for routers
    Good Ol' poly line for the pneumatic hoses. Wire reinforced tube for the suction hoses. Being in Michigan you can probably find a Parker or Fluid Connectors outlet easily.
    Aug 2014
    60
    look up exotic rubber they have shops all over mi.
    McMaster Carr.
    Jun 2010
    4256
    Suction hoses: I collect discarded domestic vacuum cleaners.
    Most engineering shops should carry pneumatic air line. Some old stuff goes brittle and shatters.
    Cheers
    Roger
    Sep 2017
    11
    The issue with using a "dust collector" system on a tool designed for a small hose is getting enough air velocity. Dust collectors are designed to draw a large volume of air at lower velocity, whereas a vacuum cleaner (shop vac) is designed to draw air at a high velocity. A shop vacuum will draw a fairly constant amount of air through its hose.
    The larger the hose diameter the better the air flow and dust removal, so in my opinion 2.5 inch is as small as I would ever want to go. I found a 2.5 inch universal reducer at Home Depot that had mounting holes so it can be bolted to the top of the dust shoe (just cut off the adapters on the bottom).
  1. What length should spindle coolant hoses be?
    By neeboy in forum Spindles / VFD
    Last Post: 10-13-2014, 12:09 AM
  2. Routing dust-collection hoses
    By ben_mtl in forum DIY CNC Router Table Machines
    Last Post: 04-09-2013, 03:02 PM
  3. Question about Vacuum Hoses
    By Mountaincraft in forum DIY CNC Router Table Machines
    Last Post: 05-17-2011, 04:25 PM
  4. Vacuum hoses
    By br1 in forum WoodWorking Topics
    Last Post: 04-26-2010, 06:05 PM
  5. Coolant Exiting Hoses keep Getting Clogged
    By JWB_Machining in forum MetalWork Discussion
    Last Post: 01-14-2009, 06:02 PM
