586,096 active members*
3,014 visitors online*
IndustryArena Forum > CAM Software > SheetCam > Making cuts longer than my table
Results 1 to 2 of 2
    Mar 2012
    33
    I have a 48" x 48" plasma table and would like to know if it is possible to cut a rectangle 20" wide x 70" long from a 48" x 96" sheet?
    I've done this in other software where the post processor creates two tiles/files (48"x48"). I'll run the "A" tile, move the material, the run the "B" tile and the cutting resumes for the finished piece.
    Is something like this possible in SheetCam? (I'm building a 6 foot high storage cabinet for a customer and would like to use my plasma table to cut the sides, doors, back, Etc.)
    Current software is SheetCam 4.0.10. Mach 3. My normal workflow is to draw the parts in Vectric Aspire, export to a .dxf. Open in SheetCam, assign the cutting operation and the post processor to create my .tap file. Then load on Mach 3 for cutting the parts.
    Thanks,
    Dan
    Mar 2012
    33
    Re: Making cuts longer than my table
    Okay I figured this one out. Drew a temporary horizontal reference line to divide the drawing manually. Cut the vectors on the intersection then saved the A vectors and B vectors into separate files. Finished cutting three 48" x 96" sheets this morning, everything came out perfect.
  1. Mach 3 making weird cuts, not following Gcode
    By justCNCit in forum Mach Software (ArtSoft software)
    Last Post: 04-06-2016, 01:24 PM
  2. Plasma table kit with 11' x 6' water table
    By genesisoffroad in forum For Sale Only
    Last Post: 10-31-2015, 06:10 PM
  3. CNC not making good hole cuts
    By Freudrick in forum Uncategorised MetalWorking Machines
    Last Post: 02-16-2013, 06:04 PM
  4. Chasing an existing thread or making one longer
    By Farmers Machine in forum CamSoft Products
    Last Post: 09-26-2012, 11:10 PM
  5. Older Themwood C50 Cuts into Table
    By Ken_McD in forum Commercial CNC Wood Routers
    Last Post: 01-19-2011, 03:02 PM
