586,438 active members*
4,006 visitors online*
Thread: cycle start
Results 1 to 9 of 9
    Jan 2016
    99
    cycle start
    Anyone rig up a remote cycle start button for pathpilot.
    I had a bit of a production type job and hated grabbing the mouse with chips and coolant on my hands.
    I contacted Tormach if they made a usb button and they said they don't recommend it.
    I should have made a holder for the mouse and a lever to tap the button.
    Dave
    Jul 2016
    140
    Re: cycle start
    I've been really happy with Milfast E stop kit.
    Tormach PCNC 1100 Series 3 w/ Rapid Turn, Fusion 360
    Jan 2007
    148
    Quote Originally Posted by toyshop View Post
    Dave
    It can be done directly, using a spare pin on the 5i25, I would not recommend USB, but it could be done,depends if the time to do it is worth it.
    Oct 2010
    670
    Re: cycle start
    Quote Originally Posted by sharmstr View Post
    I second the MillFast products! I have the basic three button version, the four button with Estop one, the tool setter and the joystick. Outstanding quality and plug and play ease.
    The Body Armor Dude - Andrew
    Apr 2013
    1788
    Re: cycle start
    I built a little box something like the Millfast unit. It is mounted beside the door on my enclosure. Three buttons -- Cycle Start, Pause, Reset -- andt uses an Arduino Leonardo to generate the required keyboard shortcut keystrokes. I already have a remote eStop from Tormach so it seems silly to duplicate it. Total cost for parts is less than $50.
    May 2008
    667
    Re: cycle start
    Would an old USB Pokeys55 which is an USB keyboard emulator work with pathpilot?
    You can program each pin as a keyboard shortcut.
    Jeff
    Apr 2013
    1788
    Re: cycle start
    Probably. All that you need is to generate the shortcut keys for Cycle Start (alt-R), coolant on (alt-F), etc.
    Jan 2016
    99
    Re: cycle start
    Thanks for the info. I'll probably try the Arduino Leonardo box.
    This was probably the only production type job I will do though.
    Dave
    Apr 2013
    1788
    Re: cycle start
    I have no knowledge of the creator nor how well it works but the unit at EntirelyCrimson has a nice looking package.
  1. FANUC 6T NO MDI & NO CYCLE START
    By mdang in forum Fanuc
    Last Post: 11-07-2017, 07:08 PM
  2. Cycle start inhibited
    By irfacnc in forum CNC Machining Centers
    Last Post: 06-26-2016, 07:08 AM
  3. Mazak VTC 20c Cycle Start
    By CCSDesign in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-06-2016, 01:02 AM
  4. Remote cycle start
    By REVCAM_Bob in forum Fanuc
    Last Post: 03-19-2007, 01:08 AM
  5. Cycle Start button
    By kaleem1 in forum Mach Software (ArtSoft software)
    Last Post: 12-24-2005, 09:05 PM
