Friday night, I was running a 1" titanium plate , on a old K.T. vertical data-mill. Program drills 2 - entry holes for a 1" wave-cut.
The night before, a 1" "heretical" insert drill , was destroyed attempting to drill both holes at 150 RPM, F.4 and .20 peck.
Someone said try a 1" spade drill at 500 rpm, F1.0 and .20 peck. I thought the RPM was too fast, but trusted the person and the drill burned up on the 2nd hole.
I want to try another 1" spade drill tomorrow. But at a slower rpm (maybe 200 rpm) , and possibly a different feed and peck.
I do think the rpm was the primary cause of tool failure.
Can someone please give me a correct RPM( not in sfm please) , and a feed rate and peck depth. For a 1" spade drill( single carbide insert, 45 degrees) drilling thru 1" thick aircraft titanium.
Thanks.
