586,114 active members*
3,156 visitors online*
    Dec 2016
    6
    X-axis running in random directions
    Hello all!
    Our computer broke so we had to reinstall Mach.
    We used the same settings for ports and pins etc. we had on the old installation.
    But now when I move the X-axis it often runs the same direction while pushing X- or X+.
    (when I swapped the X and Y pins in the settings then the Y had the same problem)
    Maybe someone here has encountered the same problem and there is a easy fix.
    Many thanks ahead!
    Jun 2005
    1730
    Re: X-axis running in random directions
    Phootsman,
    Stick a meter on the direction pin for the X axis. It should change from close to 5V to near 0V, or vice versa. The direction pin is what causes the motor to change directions.
    Russ
  1. Axis Directions
    By matttargett4 in forum SheetCam
    Last Post: 12-03-2011, 07:30 PM
  2. 5th axis help, trunion swings in both directions
    By houstonsamuel in forum Mastercam
    Last Post: 01-14-2011, 08:29 PM
  3. Y axis very noisy Changes directions?
    By bcnc in forum Syil Products
    Last Post: 04-02-2007, 01:02 AM
  4. How to switch axis directions?
    By juzwuz in forum LinuxCNC (formerly EMC2)
    Last Post: 01-01-2007, 03:05 AM
  5. Where to change axis directions?
    By WarrenW in forum Mach Software (ArtSoft software)
    Last Post: 02-16-2006, 12:32 AM
