Hello fellow CNC'ers.
Completely built right here in the USA, Romaxx has been building 3 axis CNC routers for nearly 10 years. We have them all over the world and many users with multiple units doing all sorts of operations, cutting, engraving, pick and place, scanning, polishing, Plasma arc cutting etc. They operate from Mach3 CNC control software, LinuxEMC, and other PC based software. Standard DB25 parallel port or optional USB communication as well. We are an OEM for Mach3, Moi3D and the Vectric line - Vcarvedesktop, Cut3d, Aspire software that we work in to package deals to make them more affordable. Everyone knows our customer support is second to none, we are always a phone call or an email away to help you get cutting and be successful in your CNC endeavor.
RomaxxCNC 313-937-8194
CNC Routers Desktop router robust industrial quality
After many requests, we at Romaxx are pleased to announce an even larger machine to our lineup.
Based on our very successful WD-1 3 axis machine, the WD-2 offers a larger machining area. Base size is 36" X 36". affording a full 30" X 32" work, area
Our WD-1 and WD-2 uses four ballscrews on each machine. One for Z axis, one for X axis, and two for Y axis. Each side of the gantry is driven by it's own dedicated ballscrew and they are clocked together mechanically inside the machine base, this eliminates problematic "motor-slaving" and "racking" of the gantry under cutter load . Our electronics are the time tested and proven Gecko G201X drives and 470 oz-in Nema 23 step motors. Our machines have plenty of power and rigidity to provide smooth cutting.
Base size 36" X 36"
X travel 32.1"
Y travel 30.1"
Z travel 6"
Clearance under gantry 8.5"
Drive motors 470 oz-in
Rapid travels 160 ipm
Tolerance XYZ +/- .002"
Step resolution .0005"
Construction Steel and 6160 aluminum (anodized).
Rail system Our own fully adjustable V-wheel system manufactured from O-1 tool steel.
Voltage 120/240 VAC Domestic or European operation
Spindle mounts Machine specifically for Dewalt 611, 618, Bosch 1617, Porter Cable 450, 892, Teknomotor C3140, Any cylindrical diameter on special request.
RomaxxCNC WD-2 3 axis CNC machine.
Attachment 343566
If you have any questions at all, feel free to contact me.
Thank you for the taking the time to look and have a wonderful Holiday season.
