Sorry if this is a dupe thread.
So I bought a CNC 3020 that had been upgraded with a G540.
Problems in order:
1. Scary hot steppers, pretty hot while just "holding"(G540 powered up only), and really hot when running even at a slow feed.
2. Blew fuses in the original PS, replaced fuses and ran at slow feed with no spindle(roadrunner).
3. Blew fuses in PS again, replaced PS with a good 24v 12A g540 dedicated one and ran again with no spindle. Still hot steppers, one stepper overheated/failed and blew the g540 fuse.
4. Closed problematic pump switch, forever. Ran leads out of fuse spot on G540 MB and into a breadboard, for fast fuse changes, that I was doing a lot.
5. Replaced blown stepper.
6. Finally looked at resistors the previous owner put in place. Pretty sure they are 3.5 amp, and the steppers are 2.0A.
So I thought I found a 2.2K resistor, and tried it. No holding or movement on the stepper at all. Tried just closing those pins with no resistor, nothing. Tried leaving those pins open, nothing.
I'm going to order some of those variable resistors now, but shouldn't the stepper at least work with no resistor, as the one I removed seems to have been allowing the full 3.5 amps that the g540 produces?
If you can't tell, I'm new to much of this. But any help would be appreciated.
I think I'll do a little thread on common issues with the 540 pump switch, faulty steppers and their ability to blow the g540 fuse.
