Hi guys,
I'm totally new to this but I did have some success with my new CNC router on a more simple project previously. When I load this code though, Mach jumps to line 7852 and does not move (router on or off). I also get an error that says: Delta: Internal error![movement error]. I am hoping there is something obvious wrong with the first few lines of code causing it to do this. I thought maybe it was a loose wire but I can run other code via the wizards in Mach just fine.
Thanks!
