586,070 active members*
3,543 visitors online*
IndustryArena Forum > SignMaking > Signmaking Topics > Step length chord length using alphacam
    May 2014
    45
    Hello,
    We are a one off millshop that makes very few signs, however; an increased demand is pushing me to be more efficient and learn more about this programming. One issue that I have been having is the size of the program. It seems to be related to step and chord length presets that are really precise- (.00000125). I have noticed that when I use a larger decimal my program size reduces drastically. Question is what am I doing? What is step length/ chord length? I am doing simple letters and feel like this level of accuracy is not needed. Any tips or suggestions? I am using an scm routech 220 with alphacam.
    Thanks Ben
    Dec 2013
    5717
    Re: Step length chord length using alphacam
    A chord is a line segment joining two points on any arc.
    The program is converting arcs to small line segments (short X Y moves). To put it simply; The larger the step length, the less true round the arc is. In your case, I would think that a 0.010 would be more than adequate. You really won't see any difference in the finished product. You might try even 0.050 on a test cut and see if the quality is OK.
  1. Alphacam training - Step by step
    By camtrainer in forum Alphacam
    Last Post: 03-04-2018, 09:31 PM
  2. Step Length (um) for 50w Chinese laser
    By snag96 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-14-2016, 09:18 PM
  3. AlphaCAM Report width and length in fractions
    By ruga666 in forum Alphacam
    Last Post: 06-07-2016, 08:13 PM
  4. Cut radius given chord length
    By eliot15 in forum G-Code Programing
    Last Post: 02-25-2011, 09:55 PM
  5. Alphacam to xilog (Routolink).Tool length problem
    By alanhende in forum Controller & Computer Solutions
    Last Post: 05-27-2010, 10:12 PM
