586,470 active members*
3,322 visitors online*
IndustryArena Forum > MetalWorking Machines > Knee Vertical Mills > Anilam M to DC_CNC Conversion
Page 2 of 2 12
Results 21 to 22 of 22
  1. #21
    Dec 2017
    9
    Re: Anilam M to DC_CNC Conversion
    Well, I may not know what I'm looking for as far as power supply voltage. The power supply that is on the drive module is a Power-One model HBB 15-15-A rated at 12 VDC and 1.7 amp or 15 VDC at 1.5 amp. There is a smaller one located above and to the right of the drive module that is also a Power-One, but it is rated at 24 volts. Given that my motors are 140v motors, I'm assuming I'm looking at the wrong ones. Can you direct me to where the one I need to be looking at is located?
    Oh, and thanks a million for the link to the drive manual. That is definitely my drive, and I'm sure the manual will come in handy.
  2. #22
    Dec 2013
    5717
    You are looking for a large transformer, maybe. The should be a large capacitor(s) somewhere, and a bridge rectifier. The bridge rectifier should be connected to a transformer output by black wires, the output from the bridge rectifier may be Orange (+) and Gray (-) wires, those should be connected to a large capacitor with a large resistor across it. The supply voltage can be measured across the capacitor, it will be a DC voltage around 140 VDC. It is possible that the drive PS is direct from the line, but not likely.
    Jim Dawson
    Sandy, Oregon, USA
Page 2 of 2 12
  1. conversion of anilam drives with mach 3 software
    By ptpz in forum Machines running Mach Software
    Last Post: 03-15-2011, 07:48 PM
  2. There has to be more I can do (Anilam)
    By Paraquat in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-29-2010, 04:20 AM
  3. ANILAM CRUSARED M TO ANILAM 1100S
    By Jetpylot33 in forum Uncategorised MetalWorking Machines
    Last Post: 11-08-2008, 03:51 PM
  4. servo conversion vs stepper conversion
    By contractdesign in forum Bridgeport / Hardinge Mills
    Last Post: 07-26-2008, 08:54 PM
  5. BP Series 1 Anilam > Mach conversion...?
    By arpieb in forum Bridgeport / Hardinge Mills
    Last Post: 01-05-2008, 01:17 AM
