586,268 active members*
3,482 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > 6040 4 axis Chinese CNC - Installing Limit Switches help
Page 1 of 2 12
Results 1 to 20 of 33
    Sep 2016
    13
    Greetings everyone and Happy Holidays!!
    So I bough this and I got it to work with the parallel port pc etc. I can control it with mach3 ...didnt figure out the spindle control yet so Im using manual but for now I have to install limit switches. I'm attaching a pic of the board inside the controller.
    Can anyone confirm that the MI1,MI2,MI3, M01 and MI4 Empty green pins is where the XYZ limit switches would go.
    Any help is appreciated.
    Thank You!!
    Aug 2015
    52
    Re: 6040 4 axis Chinese CNC - Installing Limit Switches help
    Please give me a picture for the card ,just a part of the card ,I can not determine the model。
    Jinan Blue Elephant CNC Machinery Co.,Ltd
    Contact:Jack
    Email:[email protected]
    Whatsapp/mobile/Wechat:0086-15064026772
    Skype:elephantcnc
    QQ:3001738567
    Web:Jinan Blue Elephant CNC Machinery Co.,Ltd.
    To be first brand CNC Router Manufacturer & Wholesaler Platform
    Sep 2016
    13
    Here are some pictures of the board:
    I just purchased that exact 6040 cnc engraver and have the same question. I belive the card you took a picture of controls the spindle. The other location could be the parallel port card mounted on the back panel. I machined a few mounts for my limit switches but have not gotten to the wiring.
    Sent from my SM-N920V using Tapatalk
    Quote Originally Posted by Little-Enterprises View Post
    Here is the picture of the parallel port board...
    Sep 2016
    13
    Nice man!!! Thank You for the images... This deff helps... I will look tonight when I get home from work at the parallel port board and take it out to take some pics and post them tonight
    Quote Originally Posted by chris190 View Post
    Attachment 344654
    I looks like the parallel board is the hook up. This is what I got from the supplier today. It seems they have it set up as a negative ground system vs. 5v signal. I will give it a try tonight. And let you know.
    Sep 2016
    13
    yes that's the same one I have as per pic below.. This is awesome!!!! Thank You
    Attachment 344686
    Sep 2016
    13
    Attachment 344654
    Also did they give you a higher resolution image by any chance ? I can't see this image to well
    Everything is now working. Attached are the settings and wiring.
    Dec 2016
    10
    I was going through the posts and saw that you added limit switches to your controller, just wondering if you could answer a couple of questions as to how you wired them, first are they configured for Normally Open or Normally Closed and is it just wired into the bridge and then to the common connector for the switch
    Quote Originally Posted by herrnoncrafts View Post
    The breakout board I have requires the switches be wired normally open. I will post a sketch of my wiring diagram. I know this is not optimal but it is working. I set up Mach3 to home +z -y and -x and works well.
    Dec 2016
    10
    Thanks it really helps.
    Sep 2016
    13
    Thanks man.. That's awesome.. im working on it now . One more question... do you know where on the board the probe wire gets connected?
    Jul 2009
    115
    Does anyone know what female connector type goes with the 5 pin connector on the board?
    Mar 2016
    44
    chris190 you use the one marked "not used" which is P11 you can look at THE CNC BLOG The CNC Blog: Z Probe Code where He explains it and has all the screens to show
    Mar 2016
    44
    Sep 2016
    13
    Quote Originally Posted by carl1961 View Post
    Yeah thats the one....in my case i just soldered the wires directly.... anyhow that was then and i no longer have that controller... ended up geting a Gecko 540 and a smooth stepper ethernet card.
    if you have any question, pls email to us. we will help you
    https://www.automationtechnologiesin...w-4-axis-6040/
Page 1 of 2 12
  1. Replies: 0
    Last Post: 05-13-2015, 01:32 PM
  2. Replies: 0
    Last Post: 05-05-2015, 11:47 PM
  3. Replies: 0
    Last Post: 04-22-2015, 10:05 PM
  4. Chinese cnc 3020 limit switches and spindle pwm .
    By RusDemka in forum CNC Machining Centers
    Last Post: 11-27-2013, 02:03 AM
  5. Installing limit switches
    By Thorpydo in forum Benchtop Machines
    Last Post: 10-19-2008, 11:48 PM
