586,061 active members*
4,660 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Has anyone used this edge finder?
Page 1 of 2 12
Results 1 to 20 of 35
    Apr 2005
    903
    The price seems fair..
    May 2005
    362
    No... never heard of it. How about a link.
    Feb 2007
    664
    http://www.lasercenteredgefinder.com/
    for the money it looks pretty cool
    this is what i use ,a bit more in price but well worth the money
    http://www.wenzel-wkp.nl/Nieuws/3D_t...ster_ip67.html
    lazer seems kinda funky to me , i sure wouldn t use it in a machine shop
    wood work i would think it may be ok
    224
    Quote Originally Posted by dertsap View Post
    lazer seems kinda funky to me , i sure wouldn t use it in a machine shop .. wood work i would think it may be ok
    Interesting synopsis.
    Why would wood make a difference with a laser dot?
    Without making this too hard, do you have any concrete conclusions metal would present kind of a problem?
    The one I own seems to work ok on metal (no wood -yet).
    I just "split" the red dot when aligning scribe marks.
    (saves using the 'ol centerpunch approach or a wiggler)
    Pres
    Feb 2007
    7
    Yap, I like it
    You are not going to get +-.002 out of it but +- .005 is more along the range. For a lot of work that is more than adequate. What I find it most useful for is very quick positioning holes that have been previously laid out.
    An example would be a series of transfer punch marks indicating where holes need to be placed. Mating to an existing pipe flange is a good example. The old way; if there were an even number of holes, I could measure the bolt circle and calculate the x and y positions and take into account any rotation of the pattern. With the laser pointer I hold the piece in place, mark the hole locations, clamp down the piece, position it under the laser and drill, reposition and drill. I do not need to measure or calculate to get the holes right where I want them.
    This little device has saved me a lot of time.
    Quote Originally Posted by Pres View Post
    Pres
    is this simple enough for you , machinist tolerances are tighter than a carpenters !
    Apr 2005
    903
    Quote Originally Posted by geo.agun View Post
    Thats pretty much what I had figured. I don't really need an edge finder but for the price I may pick one up.
    I have one, and don't find it any good for picking up edges. Seems to pick up pin pricks quite well though.
    I got an lighted electronic edge finder... I am getting good use out of that one. I don't have to worry about it rubbing while I fiddle with the computer to input the offset.
    -Jeff
    Aug 2005
    1622
    I also think there are far to many variables in a non-contact referencing device to trust it much below 1-2 beam widths and even that could be exponential the further distance it is pointing at IF the beam is not rotated on the axis to verify a true centerline.
    Their video shown in operation and only one instance was it rotated in the spindle. The runout of the beam was far too obvious.
    I don't think it is a fair comparison in competition to a standard edge finder or indicator, but I can see where it would handy in a few rough and rapid setups. Then take a true reference cut to set 0,0.
    If the head is out of tram or the work holder doesn't hold it properly on center or straight, I liken it's trustworthyness on par with a square and a plumb bob!
    DC
    Oct 2006
    586
    I will have my guys stick with the regular edge finders, the laser to me is just like digital calipers just dont trust them
    individual who perceives a solution and is willing to take command. Very often, that individual is crazy.
    Jul 2004
    374
    (see link below)
    This is no doubt my favorite edge finder. It is expensive, but you get what you pay for. I can pick up x, y, AND z off a corner in about 30 seconds total, and NOT have to offset for edge finder diameter. I experience .0001" - .0003" repeatability in x and y, and about 0.0005" in z.
    You will also need a ring gage to calibrate it in your particular machine.
    The only more accurate method that I know is to use the indicator and gage ring method, but that is a LOT slower.
    http://www1.mscdirect.com/CGI/NNSRIT...MT4NO=18267548
    Feb 2007
    664
    Quote Originally Posted by fpworks View Post
    (see link below)
    look at the second link in post #3
    Jul 2004
    374
    Yep, same exact piece, although it is labeled as an SPI product. Haimer's looks a little different, but I bet it is still made by the same company.
    I bought mine back when they cost $100 less. Even at the current price, still worth it.
    Feb 2007
    664
    there's a lot of knock offs
    i have two ,one real and one knock off
    the real one is nicely made and the knock off is less quality
    but they both function just about the same
    Jul 2004
    374
    Where can you get the cheap knock offs?
    (got a new VMC coming, and it will need one)
    Apr 2005
    903
    Thanks for all the input, I guess I'll keep my $60...
    Feb 2007
    664
    i bought mine on eBay ,but i just looked and can't find the person the was selling them
    Feb 2007
    664
    Dec 2005
    390
    I got one of those laser edge finders recently. I have a really hard time being consistent with it. +-.004 is probably the reasonable range of repeatability.
Page 1 of 2 12
  1. Question About Edge Finder
    By FLUTE HEAD in forum DNC Problems and Solutions
    Last Post: 09-29-2008, 07:21 AM
  2. Laser edge finder
    By dave6 in forum Calibration / Measurement
    Last Post: 12-10-2006, 04:06 PM
  3. anyone know where to get this optical edge finder?
    By mbwittig in forum Uncategorised MetalWorking Machines
    Last Post: 10-24-2006, 07:33 PM
  4. Anyone have a edge finder G-code routine?
    By InspirationTool in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-03-2006, 01:48 AM
  5. Manually starting spindle with edge finder
    By diemaker76 in forum Fadal
    Last Post: 04-14-2006, 12:13 AM
