586,077 active members*
3,883 visitors online*
    Mar 2010
    621
    Engraving Aluminum...
    Another question about feeds and speeds...
    Could anyone who has had some success engraving aluminum on a home made machine give me an idea of where I should start?
    I'm going to be using a 60deg 1/4 bit Onsrud 37-31, 10K RPM
    Adam,
    Merry Christmas!
    Gecko G540, Rack and Pinion Drives-X and A axis, 1/2-10 5 Start Acme-Z Axis
    4-THK HSR 25 Linear Slides, KL23H2100-35-4B, Power Supply-KL-600-48 48V
    Dec 2013
    5717
    Re: Engraving Aluminum...
    It really depends on your machine and how stiff it is. Chuck up the tool bit as short as possible. I guess I would start out light with maybe a 0.005 DOC and 10 IPM. Use plenty of cutting fluid, WD40 works good on aluminum, as does soy oil for engraving.
    Mar 2010
    621
    Thanks Jim.
    Maximum depth you've used in the past?
    Dec 2013
    5717
    I have gone as deep as 0.022 in one pass at 18,000 RPM and 20 IPM. But that is on a 5000 lb machine. Make a few test cuts and see how your machine reacts and the quality of the cut. Then increase the DOC and feed rate. Solid carbide bits like a very stable setup, and are not very forgiving to vibration and chatter.
    Feb 2006
    210
    Use a little coolant, just water will do, a mist is best. I cut at about 8ipm at at 15000
    Dave
    In the words of the Toolman--If you didn't make it yourself, it's not really yours!
    Remember- done beats perfect every time!!
  1. Engraving powdercoated aluminum
    By gmr1 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-23-2016, 01:48 AM
  2. Engraving Aluminum
    By charger19690 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-01-2012, 06:32 PM
  3. Best alloy aluminum for engraving?
    By srmaietta in forum Engraving Machines
    Last Post: 08-05-2007, 07:00 PM
  4. rfq on .125 aluminum engraving
    By cncsdr in forum Employment Opportunity
    Last Post: 01-23-2007, 01:34 AM
  5. Engraving aluminum......
    By Tyler Durden in forum MetalWork Discussion
    Last Post: 09-16-2006, 10:14 AM
