586,121 active members*
3,615 visitors online*
    Having problems with engraving - May need a new laser
    I just bought a Universal Systems X30 with a 50 watt laser. The laser was replaced in 2013. I was using CoralDraw X6
    I am trying to engrave this image
    Attachment 344402
    When I engrave it the black back ground does not engrave I have tried it on wood and acrylic
    Here is the what it looks like on wood this engraved a little on the top but then stopped. I used these setting to engrave it Power 100% Speed 20% and 500 DPI
    Attachment 344404
    Here is what it looks like on the acrylic this engraved the whole box but was light and dark. I used these setting to engrave it Power 40% Speed 20% and 500 DPI
    Attachment 344406
    Am I doing something wrong or do you think the laser is on the way out.
    Thanks for any help
    Mike
    Re: Having problems with engraving - May need a new laser
    For acrylic , power is too high , try to use 300mm/s speed and 15-20 power ,400 -450DPI is OK
    For wood ,try lower DPI too .
    Triumphlaser factory supply laser cutting and engraving machine , laser marking machine , if you need any help in the further welcome to contact us !
    Whatsapp : +86 15919906646
    Email : [email protected]
    Best regards
    David
    Mar 2008
    683
    Did you check the optics?
    Quote Originally Posted by warrenb View Post
    Yes I sure did. I just found that one of the fans are not working on the power supply just ordered two new ones. Maybe the unit is running hot ?
    Mike
  1. Problems engraving shapes on 50 watt Chinese laser with RDworks 8
    By lightedpinball in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-27-2016, 07:41 PM
  2. laser engraving problems shenhui 350
    By laserdesignlady in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-22-2015, 11:29 AM
  3. Laser Engraving Glass - smooth finish problems
    By LaserMikey in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-12-2015, 03:34 AM
  4. engraving / laser machine problems
    By noeleen in forum Community Club House
    Last Post: 05-25-2013, 08:13 AM
