586,060 active members*
3,892 visitors online*
    Sep 2014
    66
    hopeless dust shoe
    Hi.
    The dust shoe that was supplied with my machine is hopeless, so i have been looking at YouTube with a view to making my own.
    It seems there are two main types:
    1 the shoe is attached to a non moving z axis location and the brush set at table top level while the spindle travels up and down the z axis.
    2 the shoe is attached to the spindle and moves up and down with it.
    It seems to me that option 1 with a significant hole for the spindle travel would lose a lot of suction
    and
    option 2 adds weight to the z axis motor.
    My experience is limited to one hybridised design that doesn't work, as far as i can see because the brushes encircle the cutter and collapse when the downward z movement allows the hood to 'float' , and when x and y travel takes them horizontally.
    Is there a clearly superior choice re option 1 or 2 ? and please advise where I can find more designs
    Rob.
    Dec 2013
    5717
    Re: hopeless dust shoe
    I made dust shoes for both my mill and router. The one on the mill works good after I trimmed out a lot of brush.
    Attachment 344530
    The one for the router works but not as well as I would like and needs modification. I think the base needs to be cut out below the suction hose, I need to do some experimenting.
    Attachment 344544
    One of the problems is that my Porter Cable router blows a lot of cooling air through the motor and it exits out the bottom thus blowing chips to the side. I need to figure out how to channel that air in the correct direction without restricting the cooling air. I didn't have a brush that I could install so I use some thin conveyor belt I had as the skirt.
    Attachment 344546
    And the bottom view
  1. 6040 CNC Machine dust resistance, and dust shoe
    By jm82792 in forum DIY CNC Router Table Machines
    Last Post: 06-02-2016, 10:42 AM
  2. Router / Dust shoe without vacuum or dust collector / Wind Deflector
    By ajean in forum DIY CNC Router Table Machines
    Last Post: 12-12-2015, 07:42 AM
  3. New Dust Shoe
    By mmonti in forum DIY CNC Router Table Machines
    Last Post: 02-23-2015, 05:35 PM
  4. The Split Shoe - Dust Shoe
    By Kent23 in forum News Announcements
    Last Post: 12-06-2011, 07:26 AM
  5. New Dust Shoe
    By Rocketman1 in forum Maintenance DIY Discussion
    Last Post: 11-11-2011, 05:41 PM
