586,112 active members*
2,999 visitors online*
    Nov 2005
    111
    7I77 Encodervoltage is to low
    Hello,
    my 7i77 has an output on the encoderconnector pin 3 and 6 is only 4Volt, the green led is blinking. Does someone knows what can I do?
    Hans
    Jun 2009
    251
    Quote Originally Posted by Holzwurm56 View Post
    Hello,
    Hans
    What is the voltage on the 5V connector for logic power supply? If it is under 5V your power supply is to weak to power logic and encoders , you need 2A to power everything.
    If you are geting that only on 1 encoder, that emcoder is drawing to much power so it is defective, or the power wires are reversed.
    Nov 2005
    111
    Re: 7I77 Encodervoltage is to low
    Hello,
    i have use the powersupply from the pc, that was not strong enough. I change the jumper and use an external powersupply and now the encoder are working.
    Hans
  1. Small Machine Conversion - Mesa 5I25/7I77
    By Sparky961 in forum LinuxCNC (formerly EMC2)
    Last Post: 12-31-2015, 06:55 PM
