For the G0704 and many many other uses the 570 oz stepper is the best stepper made.
At 5A and 2uH inductance it is both fast and powerful. The inductance of the 425 has much higher so at 50V will make way less power at speed. At lower speeds the 425 is OK but the 570 still makes more power.
I recommend running the 570 at 50V 4A for the X and Y and 4.5A for the Z. They makes less noise with the lower current and less heat.
I run the 570 on the Z and have never had a problem but many wanted larger so I made the Nema 34 mount standard on the 704 kit that I make. I still recommend nothing larger than the 640 oz for the Z. In many ways the 570 is still better for the Z if you only look at speed.
I have no idea why your talking about a 1600 oz stepper. The head is 60 pounds and at most you might need 200 pounds of force for normal stuff. I have found that having the mill stall and not break things in a crash is a good thing. If you clog a tool and it takes 1000 pounds of force to move a cutter through melted metal its a good time to stop it anyhow.
The 570 only comes in a 8 wire with two shafts but thats what we have if you want the 3/8" shaft.
I plan on running the 570 on the bigger IH mill just to show everyone how good its performance is. Its a great motor.
youtube videos of the G0704 under the name arizonavideo99
Must be a different brand or manufacture.. The ones I used in 570oz/in are these. .High-Torque Stepper Motor, Stepper Motor, Driver, Stepper Motor kit, DC Servo Motor, DC Servo Motor kit, Stepper Motor Power Supply, CNC Router, Spindle, and other Components. Stepper Motor | Stepper Motor Driver | CNC Router | Laser Machine | 3D Prin They're 4 wire, 3/8" on the front shaft, 1/4" on the back. Never had any issues with them. More than enough for X/Y and Z. I'm running phase 1 ACME and they have more than enough torque to handle that.
Inner Vision Development Corp. - http://www.ivdc.com
Website Design & Development. Shopping Carts, SEO and more!
Automation Tech sells the 570 oz-in in the following formats:
570 oz-in 1/4"-1/4" dual shaft 8-wire: High-Torque Stepper Motor, Stepper Motor, Driver, Stepper Motor kit, DC Servo Motor, DC Servo Motor kit, Stepper Motor Power Supply, CNC Router, Spindle, and other Components. Stepper Motor | Stepper Motor Driver | CNC Router | Laser Machine | 3D Prin
570 oz-in 1/4"-1/4" dual shaft 4-wire: High-Torque Stepper Motor, Stepper Motor, Driver, Stepper Motor kit, DC Servo Motor, DC Servo Motor kit, Stepper Motor Power Supply, CNC Router, Spindle, and other Components. Stepper Motor | Stepper Motor Driver | CNC Router | Laser Machine | 3D Prin
570 oz-in 3/8"-1/4" dual shaft 4-wire: High-Torque Stepper Motor, Stepper Motor, Driver, Stepper Motor kit, DC Servo Motor, DC Servo Motor kit, Stepper Motor Power Supply, CNC Router, Spindle, and other Components. Stepper Motor | Stepper Motor Driver | CNC Router | Laser Machine | 3D Prin
