586,089 active members*
3,888 visitors online*
Results 1 to 11 of 11
    Dec 2016
    4
    60 Watts Laser
    Hi I get a new laser machine, to be more precise is this laser
    700 x 500mm 60W CO2 Laser Engraver Engraving Cutting Machine With Rotary Axis | eBay
    but the only thing I can do is engrave I tried the following setup:
    Min 30% Max 85% Speed 20
    Min 30% Max 90% Speed 10
    Min 30% Max 100% Speed 2
    Also today 29/12/16 I spend all day with the alignments of the mirrors but nothing I can't cut MDF of 1/8 inch like I said before is a Laser machine of 60 Watts anyone can help me; I almost forget I'm using RDWorks for "cutting" and engrave
    Nov 2012
    492
    Re: 60 Watts Laser
    set speed at 10 mmps set power at 75% should cut no problem how long is your tube do you have air assit
    Dec 2016
    4
    Quote Originally Posted by Bigbird48 View Post
    Hi the tube is 1000mm long also do you think i need to replace air pump for a air compressor??
    Also what about the min power??
    Nov 2012
    492
    Re: 60 Watts Laser
    1000mm is a 35 watt tube not 60 watts
    Oct 2010
    197
    Re: 60 Watts Laser
    3spin
    I have a 60w machine and I use 55% power with 12mm movement speed at 25 degrees and mine can easily cut 1/8" mdf or plywood.
    You commented on the mirrors, Are the mirrors aligned all the way to the work piece .
    Kel
    Apr 2016
    102
    Re: 60 Watts Laser
    Quote Originally Posted by 3spin3t3 View Post
    Have you got the table height set correctly? it will hardly cut butter if the table height/focal length is wrong and it looks like you have a load of adjustment on the table height.
    There are good video's on Youtube explaning focal length and checking that on each machine.
    Barrie
    Barrie @ Composite Specialities Ltd. using BobCAD V29 Mill 3 axis Pro, Geomagic Design, Bricscad V16 and MOI V3
    Oct 2015
    96
    Re: 60 Watts Laser
    Before start check:
    Go to left top corner, put piece of paper (2x2" will do) on table and test pulse. Next go to all other corners and center - and do same.
    Select most promising area and prepare to do cut test there.
    To test cut use for example small square and circle inside, say 10x10mm.
    Check distance focus (usually it is ~20mm from the nozzle at mentioned machine). You can test it as well 2mm lower and 2 mm higher from 20mm, so 18mm and 22mm (in case lens is upside-down).
    Try to use on 3mm MDF
    Speed 8mm/s
    Min power 60%
    Max power 65%
    You should fit mA meter to do not over-current your tube, but for one or two tests this values should be not too high in my opinion.
    Polish @ Éire
    Nov 2010
    787
    Re: 60 Watts Laser
    Wrong.
    1000 mm SHOULD be around 50W but new models are told to be 60W.
    CNC lasers, constructions, service
    Nov 2008
    643
    Re: 60 Watts Laser
    My old 40w was 720mm. My new 50w is 840mm.
    The 60w is 1200 but at a smaller diameter. It seem length and diameter contribute to power
    Nov 2012
    492
    Re: 60 Watts Laser
    Sorry but 1000mm is only 50 watts on start up running power closer to 35watts, anybody tells you different there wrong
    Quote Originally Posted by cinematic2 View Post
    Wrong.
    Nov 2012
    492
    Re: 60 Watts Laser
    1050mm is a true 50 watt tube 40 watt tube is 1010mm
    Quote Originally Posted by Dean448 View Post
  1. Replies: 1
    Last Post: 08-03-2017, 08:08 AM
  2. Replies: 5
    Last Post: 08-03-2017, 08:02 AM
  3. Anyone built High power laser cutting machine with power 1000+ watts?
    By pshiragu in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-28-2016, 02:34 AM
  4. Replies: 1
    Last Post: 06-24-2015, 06:25 PM
  5. 150 watts laser machine
    By Miron.Costin in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-14-2013, 11:45 AM
