586,065 active members*
4,842 visitors online*
    Feb 2014
    15
    Mach3 USB Motion Card STB4100
    Hi
    Does anyone have Mach3 USB Motion Card STB4100?
    I bought it on Aliexpress. It´s made by Hongbang Motor Co., Ltd. My question is which pin should I use for axis step and dir?
    The manual say 0 on all pins and ports for the axis.
    Pin 1, 2, 3 and 4 are used for input switches and works fine.
    Gaute
    Feb 2014
    15
    Re: Mach3 USB Motion Card STB4100
    Are there any way I can test the card to find who are who of the pins?
    Sent from my iPad using Tapatalk
    According to the manual I found, it looks like you leave them all set to 0.
    Feb 2014
    15
    Thank you ger21, Happy New Year!
    My problem is that I have set all parameters as per the manual but no life in the motors. I have contact with the board switches are working. When I enter a G code the Z motor give a short knock even if I wright G0 X100, G0 Z100 or G0 A100. The Mach3 is going to be used on my home bult slant bed CNC lathe. The A is for the auto tool change torret.
    Feb 2014
    15
    ger21
    Happy New Year
    Yes you are right. It was silly me that did a termination mistake. It´s ok now.
  1. Mach3 - USB motion card communication problem
    By Lama2 in forum Mach Software (ArtSoft software)
    Last Post: 02-14-2024, 12:21 AM
  2. Mach3 motion card
    By Roctech-Kevin in forum Roctech CNC Routers
    Last Post: 01-30-2015, 07:52 AM
  3. Mach3 Usb Motion Control Card
    By liron in forum Mach Software (ArtSoft software)
    Last Post: 07-29-2014, 10:40 AM
