586,112 active members*
2,999 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Hoping to make reliable tubing connections for a water cooled spindle
    Nov 2006
    1036
    Just bought my first water cooled spindle. 1.5 kW from UGRACNC. Also bought a small pump and two radiators (figuring that I'd use only one). Naturally all the tubing connectors are different. The connectors on the spindle itself appear to be "push to connect". The connectors to the water pump are barbed and measure about 5/16" and the connectors on the radiators are also barbed but measure about 1/4". The water pump came with two clamps to secure tubing to its connectors.
    I see a real potential for a disaster if I make a tubing connection that fails. The spilled coolant won't be great but a burned up spindle will be even worse.
    I would sure appreciate suggestions and photos of successfull tubing connections. I'm also confused about what would be the best coolant.
    Thanks. Don
    Here's some photos:
    Dec 2013
    5717
    Re: Hoping to make reliable tubing connections for a water cooled spindle
    The critical dimension is the push-in fittings on the spindle. Are they 6mm or 8mm or 10mm or maybe 1/4, 5/6, or 3/8? The black push-ring normally indicates inch sizes, but no guarantee of that. The tubing must fit the push-in fitting correctly. Then depending on what tubing you are using, it will stretch or clamp down OK on the barbed fittings on the pump and radiator. If you need to stretch it a bit, hot water works well to soften it. Go buy some good hose clamps.
    I would use RV water system antifreeze, it's non-toxic and has some anti-corrosion properties. Available just about anywhere: Auto parts, hardware stores, Walmart.
    Nov 2006
    1036
    Took more careful measurements and found that the push-in connectors are 5/16", the pump connector needs 3/8" ID tubing, and the radiator needs 5/16" ID tubing.
    Bought the appropriate connectors, hose adapters, and PVC tubing from McMaster.
    Attachment 346028
    Put everything together (except the hose clamps) and ran the pump for about 12 hours with no leaks
    Attachment 346030
    Kind of concerned about what coolant to use so picked up this at my local Frys. It's designed for cool looking water cooled computer setups. Don't care about its color but hope it will protect the spindle and radiator from corrosion and prevent microorganism growth.
    Sure would appreciate comments about this.
    Attachment 346032
  1. Crazy Idea - converting Air Cooled spindle to Water Cooled
    By BanduraMaker in forum DIY CNC Router Table Machines
    Last Post: 01-20-2018, 02:29 AM
  2. Water pump for water cooled spindle
    By bballish in forum DIY CNC Router Table Machines
    Last Post: 03-01-2016, 02:40 AM
  3. chinese water cooled spindle tubing.
    By gamba in forum DIY CNC Router Table Machines
    Last Post: 09-14-2014, 09:29 PM
  4. Water cooled 2.2 KW Spindle water fitting
    By dfmiller in forum DIY CNC Router Table Machines
    Last Post: 11-26-2013, 06:21 AM
  5. water cooled spindle vs air cooled
    By ken2010 in forum Chinese Machines
    Last Post: 10-21-2013, 06:03 PM
