586,546 active members*
3,243 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Looking for hardinge vcm 1000 with fanuc 0-md control maintenance manual
Results 1 to 6 of 6
    Feb 2007
    314
    I have big problem with my hardinge vcm 1000. It falls in alarm No 1008 and it is not describe in controller manual cause it is an external alarm. I guess it talk about it in machine maintenance manual but i just have the programmer's guide. I need some help!!!
    Jan 2008
    6
    Hello samu,
    I have VCM 600, the small version of vcm 1000. I have 400 servo alarm and 409 servo alarm. do you know what they are ?
    -Sauli
    Feb 2007
    314
    alarm 400 is overload on your first or second axis(propably x or y axis).
    alarm 409 is spindle alarm detection.
    Is these alarms occur after tool clash or heavy cutting cycle??
    If not, check your servo related parameter (#8100 to 8365).
    I ever had this kind of alarm cause i flushed accidentally all the parameters.
    I also had alarm 409 because the spindle bearing was broken.
    Let me know wath you was doing before alarms occur and if you had correct it, tell me how you did.
    Aug 2008
    Hi everyone.
    I had a Hardinge VMC 600 , to day I had an arlam 101 P/S . Can you tell me what is the problem? and how to fix that .
    Jan 2008
    6
    Thanks for responding. You are right.
    Although the problem has been solved long back, it was similar issue. The drill had wrong tool offset and crashed. Now after correction, it is okay.
    -Sauli
    24223
    Quote Originally Posted by chuong11 View Post
    Hi everyone.
    You should have started a new post.
    Check that the PWE bit is 0
    Al.
    Albert E.
  1. I NEED: DX-32 manual, 1104-2832 VMC Operator's Manual, DX-32 CNC Control
    By vettespeed in forum Bridgeport / Hardinge Mills
    Last Post: 05-31-2012, 02:21 AM
  2. Replies: 1
    Last Post: 01-25-2010, 08:13 PM
  3. feed control for hardinge TL
    By eearango in forum Mini Lathe
    Last Post: 11-20-2006, 09:15 PM
  4. Torch Height Control for PowerMax 1000
    By barnon in forum Mach Plasma / Laser
    Last Post: 08-12-2006, 05:30 AM
  5. Hardinge Mill, Fanuc OiM, how to output all programs?
    By Darc in forum Bridgeport / Hardinge Mills
    Last Post: 06-25-2005, 12:02 PM
