586,103 active members*
3,181 visitors online*
    Jan 2017
    lathe to mill lever
    hi
    I have a Smithy Granite and I have an issue with the system giving possibility to switch between lathe and mill. Few time when I was in the middle of a milling operation the spindle stop turning. it is like the system switching from lathe and mill is disengaging. The lever is locked at the right position but it is disengaging. Is someone have suggestion?
    Jun 2013
    25
    Re: lathe to mill lever
    Give us a call 800-476-4849, ask for Dave.
  1. Lever Collet Closer For Haas Tl1 & TL2 Lathe
    By Rovi in forum News Announcements
    Last Post: 07-15-2011, 08:13 PM
  2. mini lathe lever collet closer?
    By InspirationTool in forum Mini Lathe
    Last Post: 09-03-2010, 09:39 PM
  3. Wrench key of Lever Dial
    By Ramu in forum CNC Machining Centers
    Last Post: 04-04-2010, 05:08 PM
  4. Half Nut Lever
    By jroma1 in forum Mini Lathe
    Last Post: 02-22-2008, 04:58 AM
  5. electronic quill lever
    By jed102 in forum Mechanical Calculations/Engineering Design
    Last Post: 05-23-2007, 11:03 PM
