586,115 active members*
3,476 visitors online*
    Jan 2016
    10
    Thin plastic engraving?
    Hello guys
    I own a 6040 CNC machine which I'm using (still leaning..) to cut thin 2-3mm plywood and 3mm styrene.
    My questions for you today is: what would be right way to engrave the materials, thin engraving 0.15mm wide and about 1mm deep. will it be possible to use drill bit? I have some small lines to engrave at the surface (V shape bits wont do the work)
    Thank you in advance
    Dec 2013
    5717
    Re: Thin plastic engraving?
    I don't think a drill will work well, the cutting geometry is wrong.
    Would something like this work? https://bitsbits.com/index.php?main_...c2f83391b8bb90
    It still as some taper, but it's minimal. I have used these to cut all the way through 0.028 (0.6mm) brass.
    Check out Harvey tool. They have some tiny ballmills. Ive gone as small as .010
  1. thin plastic material for engraving
    By monkeyfist in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-16-2015, 09:39 PM
  2. thin -plastic- materials
    By LaserMark in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-14-2015, 12:46 PM
  3. Thin plastic engraving material
    By brian257 in forum Engraving Machines
    Last Post: 03-01-2013, 10:14 AM
  4. Building a Rockcliff out of thin plastic
    By jazzythumper in forum DIY CNC Router Table Machines
    Last Post: 02-28-2008, 04:58 AM
  5. RFQ - Cutting Thin Plastic Sheet
    By ukchris in forum Employment Opportunity
    Last Post: 12-07-2006, 03:16 AM
