Softlimits and Jog
I am wondering about the train of logic that happens when in jog mode, and the soft limit is hit. The CAMsoft CNC professional controller issues its own logic and then reads the softlimits.fil logic (if any is present). But, the stickler is, that when the softlimit is hit, then the logic in the Jog.fil gets thrown out of whack, instead of completed normally, or so it would seem.
I have reduced rates of axis movement for use in jog mode, which get reset back to standard Rapid speed when exiting jog in a normal fashion. But, in the "softlimits get hit" scenario, the Rapid speed ends up equalling the jog speed.
Here is my jog file logic. Any ideas?
~@~JOG.FIL
'This logic gets read once when the jog icon is toggled on and once more when jog is toggled off
IF\555=1THENGOTO :BEGINJOG
IF\555=0THENGOTO :LEAVEJOG
:BEGINJOG
'saving relative position before jogging
MACHHOME1 \50
MACHHOME2 \51
IF{\114+\115}<2THENGOTO :EXCEPTNOW 'skip the point save if machine is jogged during homing routine
TOGGLE 4;ON;PTSAVED :\220=1
LABEL2 POSITION SAVED IMMEDIATELY WHEN JOG+RET SWITCH FLIPPED ON;11
BUTTON15 IN; CLICK HERE, MACHINE WILL MOVE TO SAVED POSITION;0
:EXCEPTNOW
ACCEL 1;200000 ECEL 1;200000 :RAPIDSPEED 1;10000
ACCEL 2;200000 ECEL 2;200000 :RAPIDSPEED 2;10000 :LABEL1 JOGGING SPEEDS ENABLED :EXIT
:LEAVEJOG
ACCEL 1;101376 ECEL 1;153600 :RAPIDSPEED 1;\201 'jog off
ACCEL 2;101376 ECEL 2;153600 :RAPIDSPEED 2;\202 :LABEL1 JOGGING SPEEDS CANCELLED
