586,058 active members*
3,238 visitors online*
Results 1 to 2 of 2
    Dec 2016
    New plasma table won't cut
    We have a new plasma table and I've been working on getting it set up but am not having much luck. I need help figuring out what I'm missing. When I open Gcode from a file that came with Mach3 it cuts like this:
    Too much slag but it does cut through.
    Even bigger problem when I open Gcode from a file I create in Sheetcam. Most of the time the plasma will not arch. If it does, It will not cut through. It cuts like this:
    Maybe I'm using the wrong post processor? Right now I'm using Mach3 plasma post processor. Any advise on what I may be doing wrong?
    We are using a Hypotherm Powermax1250, Solid Edge ST9, Sheetcam & Mach3. Here's some pics of the set up:
    Jan 2011
    188
    Re: New plasma table won't cut
    off the shelf gcode is unlikely to be ideal for your machine/material/settings - use sheetcam to generate gcode that does work - that means create a sheetcam tool with the right lead-in, pierce height, start delay, cutting height, and speed for the material you are cutting, and set the torch pressure and amps for that material, and have mach3 configured accordingly - then test cut and adjust the tool settings until you get it dialed in for that material - plasma requires all those variable to be set just right - usually you'd have at least one tool in sheetcam for each material thickness you want to cut - for cutting small holes you can have a second tool for each material with different lead-in and slower speed
    it appears that your post processor is compatible with your machine - that's probably not the problem - you usually select a post processor based on what sort of arc and height control you have - it has nothing to do with tweaking the cut variables that affect cut quality
    once everything is set then you just have to zero the Z height accurately for every cut - if the material is warped or your Z height is off for some reason then cut quality will be off as well
    in the first picture it looks like cut speed is too slow - in the 2nd picture it looks too fast and maybe not enough pierce delay
    www.signtorch.com
  1. Replies: 1
    Last Post: 01-01-2017, 09:58 PM
  2. Ball Screws for Plasma axis on 6 x 12 plasma table
    By Joe 66 in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 12-07-2015, 04:52 PM
  3. Replies: 0
    Last Post: 12-13-2014, 06:27 PM
  4. Replies: 10
    Last Post: 02-03-2013, 06:15 AM
  5. Plasma Cart Made with CNC Plasma Table
    By Tensaiteki in forum Waterjet General Topics
    Last Post: 03-03-2012, 05:15 AM
