586,121 active members*
3,766 visitors online*
Thread: CNC Tutorial
Results 1 to 18 of 18
    Sep 2006
    36
    CNC Tutorial
    Where can I find some good tutorials on how to operater a cnc?
    From drawing a design to actualy cutting it out.
    Sep 2006
    36
    CNC Tutorial
    WOW....the site above has been my holy grail, many thanks for the reply.
    Mar 2007
    13
    excellent
    Mar 2012
    Hi my status bar on mack3 show it is runing to fast for pulley what must i do ROB
    Increase your pulley max speed.
    Aug 2010
    686
    Here is a little workflow project that I wrote up.
    KRMx01 EStop Upgrade
    Author of: The KRMx01 CNC Books, The KRMx02 CNC Books, The KRmc01 CNC Milling Machine Books, and Building the HANS Electric Gear Clock. All available at www.kronosrobotics.com
    great site
    http://www.fightech.blogspot.com
    Jan 2012
    Quote Originally Posted by msimpson99 View Post
    Not to hi-jack the thread, but I have one question about your workflow: is there a particular advantage to using EPS (vs DXF) as the transfer format between Corel and Cut2D?
    Aug 2010
    686
    I have many problems exporting DXF from many apps and importing them into other apps. Corel is no exception. One example of a DXF problem is that the circles are exported as polygons not true circles. I have also had scale problems when exporting DXF from corel. EPS has worked for me every time I get perfect objects.
    Even exporting from corel to autocad I dont use DXF. I use DWG.
    Apr 2009
    5516
    You can check out the Momus plans. Even if you don't build the machine there's great info from machine design to wiring and Mach3 setup, and cutting that first piece.
    Jan 2012
    Good to know. I'd noticed the circle/polygon effect but it seemed to depend on which DXF version you specified on export. (FWIW I'm using Corel X4.)
    Thanks.
    Aug 2010
    686
    The xport problems have not changed much Im using X5. I think its more of a DXF issue as I have problems exporting DXF from other programs as well. I have used DXF, but its allways my last choice.
    Jul 2003
    281
    Checkout my CNC projects at:
    CNC Projects
    cheers
    Bob A
    Apr 2009
    5516
    Quote Originally Posted by Lee DeRaud View Post
    Thanks.
    If your software supports it, try to export to DXF lines and arcs, not DXF polylines. It also might help to use the earliest DXF expert you can find if your software supports it (R12).
    I've had problems with EPS files where a certain software I used did not support line widths, and I'd end up with outlines over everything.
    Aug 2010
    686
    This is for a work flow I documented going from Corel Draw and Cut2D or Vcarve.
    The only thing that work well is the process I described. Export as EPS and drop into Vcarve. Works perfect every single time.
    Corel does not support arcs on exported dxf.
    Jan 2012
    Yeah, I got fooled by the fact that everything I tried exporting had circular holes. Corel does export circles correctly (at least in 'Autocad 2007' mode), but drops back to polylines for ellipses and arcs/curves.
    Quote Originally Posted by louieateinza
    Not sure that matters with Corel, but almost everything I do is 'hairline' (zero-width) anyway, for compatibility with the laser.
    Sounds like EPS is the winner...at least until the next time I upgrade software and it breaks something.
    Sep 2011
    Quote Originally Posted by Kazik_Wichura View Post
    great site
    Witaj Kaziu lol
  1. tutorial on this box
    By krymis in forum BobCad-Cam
    Last Post: 08-25-2006, 04:43 AM
  2. featurecam tutorial
    By Tebis in forum News Announcements
    Last Post: 08-18-2006, 05:49 AM
  3. Tutorial
    By honk in forum EdgeCam
    Last Post: 08-12-2006, 05:10 PM
  4. EZTRAK II Tutorial
    By Holzwurm56 in forum Bridgeport / Hardinge Mills
    Last Post: 12-18-2005, 01:19 AM
  5. Kcam tutorial
    By metalhacker in forum Uncategorised CAM Discussion
    Last Post: 06-12-2005, 01:58 AM
