Hi everyone.
Since my last post I have gotten rid of my cheap chinese breakout board and purchased a real CNC4PC board.
So I have wiring questions again.
Pictures don’t really do as well without a list, so here’s the wires I have to connect and where they come from:
5056 CONTROLLERS:
There is a total of 7 wires collectively coming from the controllers to go to the C10 Breakout Board. 3 white, 3 green and 1 red.
--------X/Y/Z “PUL +” and "DIR +" are all wired together on their independent controllers with 3 short jumpers, and then there’s a jumper from “DIR +” from Z to Y, then from Y to X, then from X to the breakout board. Red wire from X Controller goes to which pin on the breakout board?
--------X/Y/Z Controllers have a green wire from “DIR –“ to be assigned to pins on the breakout board. Which pin does each go to, Z-Y-X?
--------X/Y/Z Controllers have a white wire from “PUL –“ to be assigned to pins on the breakout board.
C41 PWM SPEED CONTROL BOARD REV 2.2
I have 5 wires coming from this board to go to the C10 Breakout board.
--------From the bottom corner of the board, near the RJ45 connector, there is “POWER”, BLACK wire in “GND” and RED wire in “5V”. These two wires would go where in the C10?
--------Kitty corner from this is “INPUTS”. WHITE wire in “PWM”, BLACK wire in “GND” and GREEN wire in “DIR”. (SEE PIC 4)
CONTINUED IN NEXT POST!!!!!
